Results 1 to 26 of 26
    Reputation: Wideside66's Avatar
    Calling all 5',10"-5',11" Stump Jumper riders.
    What size Stumpy do you ride?
    Medium or Large?
    Reputation: DonH's Avatar
    Sep 2004
    Im barely 5'10" , 32" inseam. My 06 S-works Stumpjumper is a medium. Im using a set-back seatpost and a 120mm stem w/ a non-riser bar. It fits me Perfectly! I had a large but it was too big,partially due to the longer headtube and obviously the toptube.
    The Other Dude
    Reputation: jut8's Avatar
    i am also 5' 10" with a 32" inseam and i went for the large on both my 06 SW Stumpy FSR and 08 Stumpy Carbon Pro FSR, i just like longer top tubes.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    M070R-M0U7H FR3NCHI3
    Reputation: Acadian's Avatar
    5'11" on a Med 08 Stumpjumper.
    A Large bike always seem to fit me better but I haven't ever had a chance to climb with one. I always hear that it could hamper your climbing ability. A shorter stem and a low rise bar seems like it would take care of the climbing issue.
    The large seems to put less stress on my neck.
    Jut8, What size stem and bar are you running?
    Feb 2006
    I think Specialized are good with a range of heights on the different size frames, you would be either a medium or a large at that height.
    I am 6'1 and have always gone for a large or about a 19" frame in old hardtail money.
    I prefer to run a stubby stem, 50 mm on my 06 Large SJ and going to go with 70mm on my new 08 SJ. I wouldn't be put off either way without also considering this. If a medium needed you to have too much seatpost but felt stretched then a shorter stem on the bigger frame might be a lot better.
    If I was your build, I'd probably go for a medium.
    Reputation: nic92516's Avatar
    Just over 5' 11 and 32" inseam, I went with a large 07 Stumpy. Stock stem and seatpost which I cut a bit off so I can lower it through technical sections (Shaved about 20grams off the weight as well ), have never had any issues climbing.
    07 Allez Elite
    07 Stumpjumper FSR Comp
    04 Hardrock Pro
    05 GT Tour BMX
    5-11 32 inch inseam
    Large ( both Full suspention and Hardtail )
    I'm Better known as Splat
    The Other Dude
    I am running the stock riser bar on my 08 Carbon Pro, and the stock stem i believe is a 100mm. I have only had the bike out a few times, i may want to change the stem, i am not sure yet, but if i do, i will be going shorter, not longer......possibly in the 90mm range.
    (not that fast)
    Reputation: fastale's Avatar
    I'm 5'10" and ride a medium fsr. here is a thread about the same topic:
    stumpjumper fsr '07 fitting..
    Thanks for posting the other post!
    Large seems definitely more versatile considering you can have a smaller seat post with more adjustability,
    Get a large, chop the post, throw on a new raceface short stem.
    Aug 2005
    08 Stumpy carbon pro in a large. Looks like a massive bike, but is actually not much different to the 07 carbon pro. I'm 5'10 and could ride a medium or a large, but just feel too cramped on the medium most of the time. I have put a 90mm stem on and it fits fine. The front end is quite high on the new bikes I find.
    fight the system
    Reputation: jakomonster's Avatar
    5'-10" Womens Large
    If you believe that I've got some magic beans to sell ya.
    over my head
    Reputation: bullymadison's Avatar
    Mar 2006
    5'10" 31 in inseam, Large '05 FSR . Adjust the stem , set back post and seat position on the post. My brother is same size, bought a medium Enduro because it was a good deal - when I ride that bike it feels like a kids bike.
    You will be "on" a medium as oppsed to "in" a large.
    my .02
    If a little is good...a lot must be great!- B.J. McVane
    '08 Highline;'06(?) 5-Pack;'04 Specialized Enduro; '94 GF Tassajara
    sonoranbiker
    5'11", 32" inseam. My old hardtail (Hardrock Pro) was a Med, always felt a little small. My 07 Stumpy Comp is a large, feels perfect.
    Ogden Utah
    Reputation: GTLTSJoe's Avatar
    Im also a 5'11" 32" inseam rider on a Large SJ ...... I removed the stock stem & went w/ a Thomson 90MM stem & cut the seat post down by 1.5" to get the cockpit to feel just right Merry Christmas to all you guys............Joe
    While XC riding, Beware of "NGP" (Negative Gravity Pockets) They're Real!!!
    Im about 5ft 10 an a half! Come from a large epic with short thompson stem now awaiting arrival of 08 Stumpy Carbon Pro on MEDIUM. Tried medium and large many times over, instantly felt at home on the medium, the large felt cumbersome and i felt it was reaching forward too much. I found the moment i set off on the bike i instantly knew what was right and wrong!
    gnuH
    Reputation: kiwirider's Avatar
    5'10 and my Stumpy was a medium, and a perfect fit for me.
    5'10" rode an 18" 01 stumpy hardtail, then 04 med stump fsr comp, and starting second season on 07 med stump fsr expert. 30
    inseam..
    The important thing to post with your height is the inseam. I am 5'9" with a 34 1/2" inseam. Going by height alone it would seem that a medium would fit me but I could never get knee over spindle on less then a large.
    Trying a little
    Reputation: dusthuffer's Avatar
    Nov 2006
    5'11 and 1/2
    Large 04 Stumpjumper with 90mm riser stem.
    Seat slammed forward with 16 degree tilt.
    410mm uncut Thomson seatpost.
    I never apologize. I'm sorry, but that's just the way I am.
    Come on, dare me!
    Reputation: Jerome's Avatar
    5-9 1/2" and riding a large 2004 Stump with 90 mm x 10 Thomson (X2) stem and zero setback Thomson (Masterpiece) seatpost with saddle 3/4 backed on rails (more rearward position, in other words). I'm more torso than legs, so I like having a long top tube with good standover frame.
    Reputation: arctic303's Avatar
    5'10 and 1/2
    Ride a 18" SJ HT. Perfect fit with a 50mm stem and med riser bar.
    I'm 5'10.5" with a 32" inseam and ride a large 2006 S-works Stumpjumper FSR.
    The medium felt small and the large felt much better. I'm using a 90mm stem
    with a straight Thomson seatpost rather than the setback seatpost.
    FYI,
    Thanks every one, I went with the large and it feels good. I have lots of room for adjustments now. I still have the 110 MM stem I feel like a shorter stem will set me back too much. The shop I bought the bike from has a 100% fit guarantee. They will change out the stem for free as long as it isn't scratched.
    Reputation: tonys102's Avatar
    I am 5' 11" with a 31" inseam... I have a L '06 Carbon stumpy. I thought that it was too big when I got, but I think that was just the amount of travel and the higher bottom bracket. I went with a 90deg stem to relieve the pressure on my back, and have a setback seat post.
    Building: ​Boardman 2010 HT Pro
    Current Joy: '11 Giant Anthem X
    Previous Joy: '09 Commencal Meta 5 VIP
