Results 1 to 11 of 11
    May 2013
    Building my stumpy
    Just a couple of shots of my Specialized frame .. i have just some doubts if it is a 2004 ore 2006 frame .. you are all specialist in specialized .. what do you think ?
    Reputation: VanillaEps's Avatar
    Aug 2010
    What are your thoughts on the build? SRAM? Shimano?
    May 2013
    I am allready collecting parts ..
    i have :
    bontrager wheel set with DT swiss bearings .
    Shimano XT 775 system breakset with dualcontrol set.
    XT rear derry and XT front derry with XT crank
    Fox F100 RLC Fork 100mm.
    Pro steer and ritch stem.
    going to start asamble this weekend.
    Any idea about the date of the frame ? 2004 ? ore later ?
    Aug 2010
    Specialized Bicycle Components
    Looks to me like this one. Which would make it a 2005.
    May 2013
    Update Bike
    This is how the bike looks until now ..
    Building my stumpy-20130530_204227.jpgBuilding my stumpy-20130530_204358-1-.jpgBuilding my stumpy-20130530_204505-1-.jpg
    Dex
    Dex is offline
    Reputation: Dex's Avatar
    Sep 2004
    Nice frame and build!!
    Yea, the frame does look a lot like what I was told was an 06.
    Noxubee Hills Trail System's FB page
    http://www.facebook.com/pages/Noxube...8499244?v=wall
    Dex
    Dex is offline
    Sep 2004
    But look at the seat/top tube gusset on your Stumpy verses the 05 and my 06.... ?
    May 2013
    Dex , mine is a XL frame .. 21 inch .. you can see also that the welding seem close to the ball head is a bit shorter on my frame. I am still in doubt with the Stem .. it is a bit big .. i wonder if i should find my seld a shorter one . your frame looks great too ..
    Mine has a crack in the chainstay and i repaired that but i will order a new one , just looking for them and i hope i can still order them ....
    Dex
    Dex is offline
    Sep 2004
    Quote Originally Posted by Jeroentune View Post
    Thanks! Mine is a "L".
    Did you weld the crack yourself?
    Which a lot of my info is "here say" but also was told that the 06's were the last year to have "life time" frame replacement regardless if original owner or not.?
    May 2013
    Naa h i did not weld it .. i made braces with 2 mm alu 6100. i used UHU Fest . an epoxy glue that kan pull 300kg on a square Centimeter. The Chainstay is now stronger that ever but i could a brand new one and i put the new one on .. keep the repaired one for spare ..
    Bike is almost done .. i also replaced the stem .. now i have a shorter one , still have to swap the steering tube into a longer one. brakes are on and working fine , just like the chain and cranck etc etc .. man this bike becomes a beauty.
    Jeroen
    Dex
    Dex is offline
    Sep 2004
    Cool and good luck finishing the build!
  1. Building a bike & building a computer=similarities?
    By fatcat in forum California - Socal
    Last Post: 03-31-2013, 06:23 AM
  2. Replies: 10
    Last Post: 11-03-2012, 08:39 PM
  3. New 2012 stumpy expert HT or used 2010 stumpy S-works HT?
    By crimecrusher in forum Specialized
    Last Post: 10-03-2011, 10:41 AM
  4. Replies: 20
    Last Post: 08-11-2011, 11:43 PM
  5. 2008 Stumpy or 2006 Stumpy?
    By ndmuscutt in forum Specialized
    Last Post: 03-15-2011, 07:26 PM
