Results 1 to 12 of 12
    Reputation: sgtjim57's Avatar
    Broke a crank arm today
    Just got bike back from shop having the rear brake "looked" at and pads replaced. Was half way through a 12 miler when crossing a blacktop road my foot came off the pedal with the pedal and arm still attached to my foot. Sure am glad it happened like this than during a climb. looks like back to the shop to me.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Looks like it came off because it wasn't torqued properly, but it doesn't actually appear broken (although it's probably damaged beyond repair at this point).
    Never been touched since I bought the bike so not sure how that could have happened. Do they come loose over time, like years?
    Dec 2010
    Quote Originally Posted by sgtjim57 View Post
    Yes. You should make it a habit to check nuts and bolts on the bike after the first few rides and periodically throughout the life of the bike. You'd be surprised how many pedals, crank arms and chainring bolts are loose on bikes I repair at work.
    *edit* I was a bit disappointed when I opened this thread and did not see a "broken" crankarm...just one that fell off due to negligence BTW....how long did you ride that bike NOT noticing it was loose...?
    I have a Camber that I have been riding for more than a year so this one has sat without use. Camber is being repaired so I had to break out the back up. I would think I would have known it was loose but I guess I missed that while riding. It's been ridden by friends during this time and i have ridden it also a few times.
    Actually as you can see in the picture the arm failed, the bolt is still in the bottom bracket and it is still tight.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    That looks like the self-extracting ring, not the bolt.
    That is exactly what Mark at MOAB said when he looked at the bike and tyhe crank arm. Nothing to do with maintenance, bolt tightening or anything I as a user could have done just riding. Left it for them to repair, picked up my Camber Comp 29er after a warranty replacement on the rear triangle. thanks MOAB
    Well, the self extracting bolt doesn't hold the cranks on, it only comes into play when you try to take them off, but it remains on the crank (like in your picture) What is the condition of the actual anchoring bolt? Did it shear? That would be a "failure". A highly marred or even un-worn bolt would indicate it was loose.
    Bikes still at shop so I will have to add when I get it back. The bolt appeared to be fine, the mechanic said it was. Only the self extracting bolt failed and if it doesn't do anything not sure why that happened.
    Dec 2010
    I'm guessing something was loose and you didn't know it. It's probably come loose over time, especially if you haven't touched it since it was new. I'd bet the crank arm was loose but the bolt was still partially threaded in the spindle, and when you started pedaling hard it just sheared that self extracting bit to pieces.
    That's happened time and time again in the history of MTB Good that you got it fixed.
    The self-extracting bolt is not needed for anything but extracting, it could be removed, and before self-extracting bolts were the "norm" we used crank-pullers that threaded in there and pushed against the spindle. Now with hollow spindles that's not possible, but self-extracting bolts were already invented so it was a good idea to use them for the taper-lock external BB cranksets like Truvativ and Race Face.
  1. Replies: 41
    Last Post: 03-06-2014, 01:24 PM
  2. Broke the 10 mph barrier today
    By Wherewolf in forum California - Norcal
    Last Post: 03-07-2013, 05:32 PM
  3. Broke my chainring shifter today, what to do now
    By JuliusDarius in forum Beginner's Corner
    Last Post: 09-11-2012, 07:08 AM
  4. Broke my Dos Niner today
    By mtnbikefj in forum Salsa
    Last Post: 02-08-2012, 01:52 PM
  5. Broke my crank while all-mountaining today
    By veryavgwhtguy in forum All Mountain
    Last Post: 01-01-2012, 11:31 PM
