    Brake mount for enduro e150 fork
    Hi All,
    I'm moving my avid juicy 7 caliper on my new enduro frameset with e150 fork. I'm having a tough time finding the right caliper mount. Does anyone know which size fits for a 160mm rotor?
    May 2005
    none, you have to use a 203mm rotor
    Or if you don't mind a jury rigged design, take a normal front 160mm adapter and add two 4mm spacers between the fork and the adpater. This will push the adpater out far enough.
    Highly NOT Recommened
    Thanks! I was hoping to use the 160mm rotor temporarily until the 203mm arrives next week. I guess I'll have to wait. Can I just use a 203mm IS adapter or do I need a special adapter?
    May 2005
    this is the only kind that works.
    http://www.bikewagon.com/Brakes-Leve...-p7475502.html
