Results 1 to 5 of 5
    Brain fade knob will not turn.
    Need to see if I can get any help. I just bought a Epic Comp. Do not know the year for sure but it is probably a 2007. It has literally 35 miles on it, basically new. The problem is the brain fade know will not turn at all. Any body have any guidance.
    old fart
    I assume you have the EPIC shock with the integrated brain. There is no magic solution here. Just lube with WD40/CRC556 or similar and leave to soak. Should free it up. Otherwise you're going to have to dismantle.
    I have a 2011 epic with brain fade and am told it is only serviceable at Specilized. Nobody in town that I know of will touch it. When they are locked tight in one direction or the other I know they get pretty tight. Did you try nudging it with a pliers?
    It is the original style fox shock with the brain extending up from the top of it. I tried nudging it with pliers but it would not budge and I certainly don't want to break it. I took it for a short ride on the trails and where it is set felt pretty good so maybe I will leave well enough alone.
    I wil try soaking it in WD-40 tonight and try a little more tomorrow. The guy I bought it from bought it new in 2007 and rode it twice, never even off road and it has sat inside his house since then. I don't think the brain fade knob has been touched since it left the bike shop that year.
    If any body else has any ideas or guidance let me know
    Thanks.
    old fart
    I'd bet that the WD40 will work, just prolonged inactivity will have caused it to bind...
  1. Fox Brain Fade dial issue..
    By Eric C. in forum Shocks and Suspension
    Last Post: 04-10-2013, 12:49 PM
  2. Fox Float R w/ Brain Fade SNAFU -- Oil anyone?
    By river_tool in forum Shocks and Suspension
    Last Post: 04-04-2013, 02:43 PM
  3. DUC 32 lockout knob will not turn
    By Jon Richard in forum Maverick
    Last Post: 03-07-2012, 01:12 PM
  4. Fox Brain Fade vs. Specialized AFR Shock ???
    By CircuitMan in forum Specialized
    Last Post: 07-22-2011, 05:39 PM
  5. Float r w/ Brain Fade Rebuild
    By impact23 in forum Specialized
    Last Post: 01-08-2011, 04:29 PM
