Results 1 to 5 of 5
    biggest tires on Pitch.
    What are the biggest tires you can fit on a 09 pitch with stock DT rims?
    Thanks.
    I've had 2.5s on, but the rims are a bit narrow for that really. You have to pump them up a bit harder than normal to stop them rolling around.
    Got Stan's Flow rims on mine now
    Okay, I was looking at some 2.4's and seems that they should work fine then. Thanks for your help!
    Reputation: minimusprime's Avatar
    the frame/fork will easily fit 2.5's. The profile of 2.4 and larger tires does kinda suck tho on the stock wheels. Run em at 35-37psi and you're g2g.
    Cool, thanks! I have a feeling I am going to blow through the stock wheels quickly anyways so then I guess it would not be a problem after that.
