Results 1 to 10 of 10
    Reputation: papatini's Avatar
    Jun 2010
    Autosag and extra weight
    When I purchased my 2013 Specialized Epic Comp recently, they set up the autosag for me in the shop. I was just wearing street clothes.
    When I ride, I have a full 100 oz hydro pak, with plenty of tools and tubes, so it's a bit added weight.
    Should I reset the autosag? The o-ring is sitting right at the end of the stroke. Is this okay?
    Thanks for your help.
    Chris
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    it's so easy to do, just try it !
    Frenchspeaking 29"ers community site http://VingtNeuf.org
    Jan 2013
    Reset it. It should be set with your riding weight. Also take note of the pressure and check after a few rides to make sure your not losing air. Easy to do. Pump it up, sit on the bike and push the valve
    Oct 2012
    Remember to give it 300psi..
    Yes, it's easy to do and will make a difference in how the bike rides.
    Reputation: Devastazione's Avatar
    Dec 2009
    Speaking of the mighty Autosag, I've never really bonded with the whole thing as I tend to keep my brain equipped Futureshock on the stiff side. The more I've become confident withe bike( Stumpy FSR) and left behind the concept of my xc Epic I've progressively lowered the shock pressure close to the sag given by the Autosag procedure.
    Question is : give it 300 PSI,push the button and hear the massive "pffssshhhh" and then what ? After the massive "pfssshh" is gone when do I have to release the button ? If I keep my finger in there the shock keeps losing air,at a minimum but it does,does it stop at some point ?
    When I put mine at 300, sit on it and then push the button, mine kinda like lifts me up.. I can't recall just holding it down a long time, but think it stops itself..
    No talent hack
    If you hold the button down, the shock should stop losing air when it hits the 25% sag mark. The bike will feel like it jacks up a bit like described above. Press and HOLD the button or valve.... don't diddle with it, just hold it down.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    EXACTLY what he said.. (Thanks for a better explanation Knight511).. But do exactly as Knight says..
    Reputation: timmaayyy's Avatar
    May 2010
    Or you could bypass the autosag feature and do it the old fashion way. I trust my ruler more than I do that little red valve. Just saying...
  1. Fox 32 vs 34, worth the extra weight?
    By paulpalf in forum 29er Components
    Last Post: 08-03-2012, 10:46 PM
  2. Autosag retro fit?
    By kiwi_matt in forum Specialized
    Last Post: 01-26-2012, 03:27 AM
  3. Nevegal: worth the extra weight for UST?
    By fiveo in forum Wheels and Tires
    Last Post: 09-30-2011, 04:05 PM
  4. Where is the Extra Weight?
    By Cary in forum Weight Weenies
    Last Post: 06-07-2011, 12:46 PM
  5. Adding Extra Weight
    By dnoyeb in forum General Discussion
    Last Post: 03-22-2011, 05:46 PM
