Results 1 to 9 of 9
    Dec 2013
    Autosag; inflated red valve by mistake
    Hi,
    i just got my new Camber this weekend. Great bike but when i wanted to adjust te rear suspension a inflated te red valve by mistake... Cranking it up to 300psi an then adjusted the sag.
    All seems okay but what anyone knowes what might been damaged?
    No talent hack
    I wouldn't think anything would be damaged. It is just a valve higher in the chamber that lets the piston sag to a certain level. You may be able to damage something if you inflated the port with the piston lower than the port (possibly), but I would imagine you are fine and this isn't the first time someone has done this (not me, my Monarch won't let you do this).
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    Reputation: timmaayyy's Avatar
    May 2010
    Not to cause worry but I think it says somewhere in the manual if you do that then you could cause some major damage....
    Dec 2013
    Quote Originally Posted by timmaayyy View Post
    That is why i am a
    bit worried... But manuals are manuals.
    Suspension (Fox CTD) seems okay but haven't ridden on the trails jet.
    Reputation: Biking Brazilian's Avatar
    It does not.
    Reputation: HAL 9000's Avatar
    Quote Originally Posted by Camber1979 View Post
    how is this even possible?
    i mean how did you even get the shock pump to thread on the red valve?
    there is like no space between the valve and the shock to even thread it on...
    2ts
    2ts is offline
    Mar 2011
    Nothing to worry......I did the same mistake 2 years ago when I first got my 2012 stumpy.
    May 2010
    Quote Originally Posted by Biking Brazilian View Post
    It does not.
    Specialized® IV Shocks with Autosag
    Step 5.
    That is assuming you'll bend the pin if you connect a pump, if he didn't then he is fine. Bending the pin is the irreparable damage they are talking about.
    OG Ripley v2
    Carver 420 TI
  1. Replies: 0
    Last Post: 03-28-2013, 09:16 AM
  2. Replies: 13
    Last Post: 11-27-2012, 12:22 AM
  3. Replies: 14
    Last Post: 06-21-2012, 06:59 AM
  4. Height of common 650b tires inflated?
    By rideit in forum 27.5
    Last Post: 05-22-2012, 06:17 AM
  5. Volume of Inflated Pugsley inner tube.
    By davesport in forum Fat bikes
    Last Post: 10-26-2011, 12:45 PM
