Results 1 to 8 of 8
    Reputation: Ksousa81's Avatar
    Auto sag for the first time!?!
    Just picked up a camber comp carbon with fox ctd with auto sag
    Took the shock to 300 psi sat on bike took off red cap pushed down on little button as it released air and blue oily stuff.... What did I do wrong!?!
    Dec 2011
    Do you weigh 250lbs?
    Yes I do
    Dec 2011
    It is supposed to release air. That is how it works. As for the blue oily stuff, if there is a ton of it, you have an issue. If it is just a tiny bit, don't worry about it, that is normal.
    I brought it up to 300 again and pressed the autosag button, this time as the air released as it started sag I got alot less blue stuff on my finger and frame...
    Dec 2011
    You should be fine
    No talent hack
    When I auto-sagged the Fox shock while I was testing them, the shop said the bikes do that for the first few times and it is normal.
    Now on my Monarch on my Camber Comp, it has never oozed oil.
    2013 Specialized Camber Comp
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (the commuter)
    Thanks! i was getting nervous for a few moments there!
