Results 1 to 14 of 14
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    Anyone fit a tapered fork into a straight HT, on a Camber or similar?
    I've thought of upgrading my fork, but my 2012 Camber 29 has a straight 1 1/8 head tube, and the idea of spending a lot of money that won't really work on any modern frames leaves me a little cold.
    I've seen here and there that Cane Creek offers a headset combination that could possibly allow for the use of a tapered fork in a straight tube like mine, by putting the lower cup on the outside of the frame.
    40-Series
    Has anyone done it? On a Camber or similar bike? I know older Enduros and Stumpies are still running.
    By tapered, I take it you mean a fork that goes from 1 1/8 to 1 1/4 or 1 1/2.
    These 2 sizes are already bigger than your 1 1/8 head tube so the fork can not fit. The tapered headsets allow a fork that is tapered to fit into a larger hear tube.
    JimPz
    Cleavage Of The Tetons
    Ummm...no
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    May 2005
    The 2012 Camber should have a tapered steer tube. The lower cup might be 1 1/8 but that can be changed.
    M5 hydroformed tubing, 29" geometry, tapered HT, PF30 BB, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, bolt-on cable guides, 110mm travel
    Competent User
    Mar 2012
    The base model 2012 Camber 29 uses the 2011 frame, and is M4, and a straight headtube. I wish I had known the difference at the time, but here we are.
    2012 Specialized Camber 29 | Mountain Bike Components and Reviews
    Anyway, I'm not an idiot, but I found this article, and wanted to know if it actually existed or was just some nonsense. It was a while back and yes is probably too good to be true, but it didn't hurt to ask.
    New Cane Creek Headset System Allows Tapered Steerer Forks on Straight 1-1/8? Headtubes
    May 2005
    Didn't think they would do that. I figured most stuff that new would have it. I just went to the archives and figured they'd all be the same. If your planning on keeping it just get another 1 1/8. A lot cheaper than new frame.
    Also, might consider dropping BB or Motion control damper in.
    Competent User
    Mar 2012
    Any excuse to look for a new bike...
    May 2005
    I edited my post above and suggested dropping BB or Motion control damper in. But I understand you "excuse" Ha.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by Mr.Quint View Post
    You bought a base model bike, why not just save your money and get a nice straight tube and not have to buy the more expensive fork, headset and thru axle hub front wheel?
    Wait whuuut, who did he tell you that!?!?....
    Competent User
    Mar 2012
    Quote Originally Posted by JMac47 View Post
    To make it stiffer, and to be able to use the fork on a future frame. I already have convertible hub wheels. But either way, I wasn't asking for advice, I was asking if anyone had seen or done this in the wild. It looks like no one has, which I suspected.
    Lots of people have, just get a lower cup. It's that easy. Have you asked your LBS?
    Competent User
    Mar 2012
    Quote Originally Posted by rideit View Post
    I haven't yet. He's a great guy, but doesn't always know all the things I need to know. Checking with the hivemind.
    Ask him to look these up in his Quality catalogue, and find the right one.
    Problem Solvers
    NedwannaB
    Well allrighty then. This is the backseat quarterback Interwebz. Sounds like you have it figured and the pieces are there, you should just go for it.
  1. Straight 1 1/8 Fork on a Tapered Frame?
    By anirban in forum Bike and Frame discussion
    Last Post: 06-18-2015, 05:40 AM
  2. Tapered fork on Reign straight headtube
    By imfullerRVA in forum Giant
    Last Post: 02-12-2013, 06:31 AM
  3. Straight tube fork in tapered headset?
    By SS Hack in forum Tooltime
    Last Post: 10-17-2012, 09:25 PM
  4. Questions about tapered fork on straight head tube (HELP)
    By Muffinhead in forum Shocks and Suspension
    Last Post: 08-25-2012, 11:19 PM
  5. Straight steerer fork in a tapered headtube?
    By Yuri Natenpuhl in forum Shocks and Suspension
    Last Post: 04-26-2012, 03:56 PM
