Results 1 to 5 of 5
    any tricks to removing the rear pivot bearings?
    on my 07 SJ FSR? There are 4, two on each side, so i can't get to the inside to knock them out like I did all the other bearings. I'd hate to buy a $100 blind bearing puller for 4 bearings?
    Any tricks to getting them out?
    wafflemaster
    I had my Specialized LBS remove those for $5, I couldn't get them out, rest weren't bad. They had a 'special' tool. Not sure if it was special for that pair or the same thing you rig up w/ bolt & a socket (which wouldn't work in this case).
    wafflemaster!
    May 2005
    there is a machined shoulder inside that keeps the bearings seperated.
    So, you need a blind hole bearing puller or the ability to slowly tap the bearing out from the other side
    an cheaper example: (Not Metric) http://www.harborfreight.com/cpi/cta...112&zmap=95987
    will a non metric one work? Looks like it just expands to fit.
    May 2005
    a 5/16th one shoould fit those 8mm bearings.
    1/2" shoul fit 13mm
    a 9/16th should fit 14mm
    3/4 should fit 19mm
    1" should work on 25mm
    other sizes, IDK
