Results 1 to 6 of 6
Thread: any difference?
    any difference?
    any difference between the 05 enduro frame and the 06 one?
    the 06 has more travel because is different or just because has a different shock?
    Reputation: .thumper.'s Avatar
    Jan 2005
    I assume you are talking about the Enduro SX Trail because all the other Enduros from 05 and 06 have 150mm rear travel. I have read (I don't remember where - maybe nsmb.com) that the SX Trail frame actually has different geometry than all the others - not simply shock mounting points, etc. So, in other words, it may look the same, but it has a different frame design.
    YES i'm talking about the sxt.so if i put a DHX shock on a sxt 05 i will get the same travel of the sxt 06?
    Aug 2005
    They are different frames
    Quote Originally Posted by Jakewake
    The 2006 SXT is completely redesigned around a longer shock and 6.6" of travel. You will NOT be able to put a '06 DHX Coil on an '05 frame.
    Theres your answer, see this thread for more:
    http://forums.mtbr.com/showthread.php?t=98458
    thank you
    Aug 2005
    No problem, glad to help.
