Results 1 to 12 of 12
    Reputation: upstateSC-rider's Avatar
    Any common problems with the 04 Triad on the SJ?
    I've been reading about problems with the Septunes and Triads on later bikes getting stuck down. Do the 04's have the same problems?
    Thanks.
    Lou.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    Jan 2005
    Quote Originally Posted by upstateSC-rider
    Thanks.
    Lou.
    Haven't experienced problems myself and never noticed anyone else on this forum have problems with this shock.
    Gravity Rides Everything
    Reputation: endurowanker's Avatar
    I think the triad was generally considered a better shock than the septune. i fried the pro-pedal on my septune in about 5 monthes (lotsa miles, but still)
    those FSR100 frames rock. you're lucky to have one.
    Thanks guys, makes me feel better.
    It always seems like I when I buy something I find out something bad after the fact. IE, interest rates go down, bad consumer reports article, yada, yada, yada.
    Lou.
    Your Imaginary Friend
    Reputation: CranxOC's Avatar
    I have about 4,000 miles on my Triad and haven't had a single problem with the shock itself. The bushings are another story as they wear out pretty quickly which creates some "play" in the rear end of the bike (pick the bike up by the seat with the front wheel on the ground and, if you notice a little "click," your bushing probably needs to be replaced). It's a very cheap, quick fix though so it's really not that big a deal.
    There's a fine line between courage and foolishness. Too bad it's not a fence.
    Quote Originally Posted by CranxOC
    betd.co.uk <--- pick up a strong shock bushing set. i had one on my enduro and it tightened everything right up.
    Jan 2005
    Quote Originally Posted by endurowanker
    Yep, I'll have to replace the DU bushing for the 2nd time already (got the bike in oct 2004).
    After this set I'll probably order a betd set.
    I tried getting in contact with them to find out what I needed and never heard back. Are they usually this slow?
    Is there a U.S. distributor?
    Lou
    Lou
    i ordered direct. freight was pretty reasonable. they even gave me wholesale price cause i work for a shop.
    they were quick for me. i don't know if they're having problems or what...
    It's been several days and still no response. I wonder what the deal is. I'm not sure I'd order from a company that is completely unresponsive.
    Goathead Gladiator
    Reputation: bwolmarans's Avatar
    May 2005
    I just ordered DU Bush + reducers set direct from Fox, $24 with shipping to SoCal. My shock has been bombproof so far and I'm 215lbs. I've serviced it once in 18 mths following the quicktime video on fox's website, easy to do. It was amazingly clean inside. I love it, I can't imagine not having a rear shock with lockout, it just seems like such a no brainer. I'm lighting fast flicking in and out of lockout too now, can do it without thinking.
