    Reputation: ocie's Avatar
    ALRIGHT, I'm confused
    What the hell are the front and rear thru axle sizes on the 2011 Epic Comp Carbon 29er? I can't remember for the life of me and I'm looking at options for new wheels.
    Reputation: goneskiian's Avatar
    Sep 2004
    Front is a standard quick release. The front hub does use the OS28 end caps though which are stiffer than some thru axle set ups.
    Rear is the Syntace X-12 142 system.
    Specs for the Comp Carbon:
    http://www.specialized.com/us/en/bc/...cname=Mountain
    Roval wheel tech info:
    http://issuu.com/jrun1974/docs/cyclo...ayout.xml=true
    Thanks for the info, but what's the standard QR size?
    waiting for a piece (.45)
    Reputation: SpecialWarr's Avatar
    9mm axle, exterior diameter, Front
    5mm skewer, outside diameter
