Results 1 to 9 of 9
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    Advice on oversided seat rails/seat post compatability.
    I'm looking at purshasing the Specialized Toupe Pro with jumbo carbon rails.
    Specialized says: •NOTE: Oversized 7x9mm carbon rails are not compatible with seatposts equipped with side-load clamp mechanisms for 7mm round rails
    Specialized Bicycle Components
    Will it fit on a FSA K-Force post? (Not side load)
    in Bolton, Ontario, Canada - photo by thatshowiroll - Pinkbike
    Thanks for your help.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    Specialized sells adapters for some of the seatposts. I know the Command post now had replacement parts to make it compatible with the carbon rails.
    14 Aurum, 16 Fuse, 17 T130
    If its not a side load your fine,i have the phenom pro on an easton seat post and no problems.
    Jan 2009
    Quote Originally Posted by bruce219 View Post
    After some research I agree with this.
    Now my only concern is the length of the saddle cradle on the post.
    I suspect carbon rails would need a longer "bed" to sit in.
    I don't think so my cradle is pretty small,the saddle fitting info just said make sure cradle is not close to where rails start to turn back up.
    Jan 2009
    Thanks for the info. My new saddle is in the post and on it's way.
    Reputation: Scottesq's Avatar
    I have the carbon railed phenom and I use the Thomson Masterpiece. The Thomson Elite works good too.
    2013 Epic Comp 29er
    2014 Stumpjumper Evo HT
    2011 Roubaix
    Any thoughts on the Romin Evo Pro?
    MCH Co-Captain
    I used one on my single speed.
    I think it's a good saddle especially for long rides even though it's technically a road saddle
    2013 Epic Comp 29er
    2011 Roubaix
  1. Thomson Elite Post: Head too narrow for seat rails?
    By 007 in forum General Discussion
    Last Post: 03-22-2014, 10:25 PM
  2. Replies: 68
    Last Post: 10-01-2013, 06:31 AM
  3. Seat Post Compatability
    By Mudpuppy23 in forum General Discussion
    Last Post: 10-24-2011, 07:49 AM
  4. 2011 Scalpel seat post/ seat clamp issue
    By scalpel226 in forum Cannondale
    Last Post: 08-01-2011, 09:19 PM
  5. Thomson seat post base on an Easton seat post?
    By steveccnv in forum General Discussion
    Last Post: 06-23-2011, 06:51 PM
