Results 1 to 2 of 2
    Adapter Needed for BB91 to convert Xtr 970
    I bought a used 2010 Specialized Epic Comp with a BB91 press fit bottom bracket ..came with the SM-BB91-42A bearings already pressed in...I need the Shimano code Y1L902000 spacer 2.5mm and the Y1F31600 ring...Where can I buy the spacer and ring with out buying the complete adapter unit?
    In stock at Shimano
    lbs contacted shimano...able to order just the spacer and ring..5 bucks for both..
