Results 1 to 5 of 5
    Reputation: J273's Avatar
    650b pikes on 2010 enduro s-works
    I want to get some pikes for my enduro and replace the current lyriks. what's the difference between the 26" and 650b pikes?
    If I was to put the 650b versions on there am I likely to cause the frame to fail being carbon? I know warranty wise I'm allowed 170's I'm guessing putting the 650b model of pike will void the warranty?
    As anyone done this or am I best to stick with the 26 model?
    The 275/160 Pike is about 10 mm longer than the 26 version and the same length as the 26/170 Lyrik. Should not effect your warranty at all.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I seriously considered putting the 150mm 650 Pike on my SJ, just for future sake, but i went with the 26" 160 version. Both forks are the same height so it was a serious thought.
    14 Aurum, 16 Fuse, 17 T130
    Yeah that's why I'd rather go for the 27.5 pikes for futures sake as you say rather than buy the 26" Version.
    So you guys think it wouldn't affect my warranty Then? I won't be getting rid of the lyriks as they'll be going on my other build.
    Sent from my SM-N9005 using Tapatalk
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Since you are getting two just get one of each and sell the other?
  1. S-WORKS ENDURO 2010 SHock UPGRADE
    By jaidylim in forum Specialized
    Last Post: 11-13-2012, 02:29 PM
  2. 2010 S-works Enduro ?
    By goRz in forum Specialized
    Last Post: 09-10-2012, 10:58 PM
  3. 2010 S-works Enduro Q-Factor?
    By robatki in forum Specialized
    Last Post: 08-08-2011, 06:56 PM
  4. 2010 Enduro S-Works value?
    By bb47 in forum Specialized
    Last Post: 07-04-2011, 06:51 AM
