Results 1 to 10 of 10
    Reputation: ThePunisher's Avatar
    Feb 2006
    New question here. 6.5" x 1.5" on Stumpjumper FSR
    anyone here ever tried running a 6.5" x 1.5" shock on an Stumpy instead of the 7.25" x 1.75"
    would there be any problems running this setup?
    Doesn't sound good
    Quick math says you are squating the rear end of the bike down an inch. That should throw off your head angle quite a bit, really slack, and shorten up your available travel.
    Feb 2006
    what if I run a 100mm fork up front with that?
    should make for a fun short travel bike with agressive geometry no?
    I would try anything, it is fun to get different bike feels. How much to spend on it is up to you.
    Quote Originally Posted by ThePunisher
    Shouldn't be a problem. 6.5 x 1.5 IS the stock setup on a Stumpy FSR...Depending on the year. you didn't mention what year your FSR is. 7.25 x1.75 would make my the rear suspension on my stumpy over extended.
    Um are you serious?? Your bike would be sitting on the ground, pedal bash, rubbish angles the works. By shortening the i-i length by 3/4" your bike with no sag would be similar to with current shock at 50% shock compression. Let all the air out of your current shock so the shock fully compresses, look at the bike, does it look ok? Does it look like a fun short travel bike? No, it looks stupid, the head angle would be really slack, and bottom bracket very low, not fun at all. The only think you could do to make it a shorter travel bike would be to get a shock with the same i-i measurement and less stroke, maybe 7.5"x1.5" or similar.
    MIght want to check your forks. 100mm is the front fork travel on a stumpy FSR anyway, again depending on the model year, you've not told us the model year.
    Shock Swap?
    I have an 05 FSRXC with the 6.5x1.5 Rear shock. Can I switch to the newer 7.0x1.6. What would be the advantages???
    BM and PQ Trail Rep
    Reputation: bankerboy's Avatar
    Am I missing somthing?
    As I understand it the numbers in the shocks work as follows:
    The first number is the length of the shock, eye to eye.
    The second is the maximum distance the shock will compress before bottoming out.
    Using the standard 7.5 X 1.75 shock at maximum compresion would yield a shock length of 5.75 inches. If you switch to the 6.5 X 1.5 your shock would compress to only 5 inches. If this happens, the rear linkage will most likely hit the frame.
    This is why it is so hard to replace the existing shock with a standard 7.5 X 2.0 shock. That compression distance is 5.5 and that compression distance will cause a collision between the linkage and the frame. I know that is not good.
    How could a smaller shock be helpful without creating frame damage?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by OCscs
    Don't. There are really no advantages - it'll thrown off your geometry and make your bike ride worse.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
