Results 1 to 3 of 3
    5th element shock replacement
    I have a 05 specialized endura expert.extera small.What shock can i replace the progressive 5th element with.I like to get a coil before i go for air shock.Thanks
    Reputation: 'size's Avatar
    in a nutshell: fox dhx coil, avalanche chubie or woodie, romic, cane creek db, fox vanilla rc & marzocchi roco (i believe) have all been fitted on med and large enduro's. see this thread for a ton of info.
    i do not recall if any small or x-small frames have been upgraded or what the seat tube clearance is like for the reservoirs on the above shocks and any possible shock link interference. i wouldn't imagine an issue with the vanilla rc, romic or the avalanche shocks since their res's are so short (or no res at all). the dhx, cc & roco may be an issue.
    good luck!
    Thanks for the info
