Results 1 to 5 of 5
    Reputation: J273's Avatar
    420mm reverb in large enduro
    Does anyone run a 420mm length reverb in a large 2010 enduro?
    Can you tell me if the post fits all the way in the frame to the collar?
    Many thanks
    it fits just shy of the collar. If lower mine as far as the collar i start to get resistance. Mine sits ok with the bottom of the collar about 10mm from the seattube. Its a 2012 125mm drop reverb.
    Thanks.....hopefully itll be ok then.
    Could you do me a favour and measure the whole of the post out of the frame to the seat mount clamp?
    Would be appreciated if you could.
    end of seatpost to the middle of the two saddle rail clamps is 416mm
    Thats great...Much appreciated fella.
  1. Rockshox Reverb Enduro 2011
    By lmgarcia in forum Specialized
    Last Post: 12-09-2011, 09:49 AM
  2. Rockshox Reverb on Enduro SL
    By jabba69 in forum Specialized
    Last Post: 07-02-2011, 04:18 AM
  3. what length Reverb for Large 575
    By Yeti_Rider in forum Yeti
    Last Post: 01-21-2011, 07:45 PM
  4. Going rate for On One 420mm fork?
    By bad mechanic in forum General Discussion
    Last Post: 10-19-2007, 11:30 AM
  5. Need Rigid Fork, 1'' Steerer, 420mm A-C
    By wyatt in forum Singlespeed
    Last Post: 03-03-2006, 06:43 PM
