Results 1 to 2 of 2
    Reputation: griffter18's Avatar
    26mm Shaft Clamp required
    Anyone know where I can get a 26mm shaft clamp (used for holding hollow tubes - i.e. suspension)
    Would prefer uk if possible but don't mind ordering if I have to
    Specialized list one but I can't find a dealer in the UK who can seem to order one (part S2018056)
    Alternatively has anyone made one?
    MTB: Stumpy, Enduro, Hotrock, Commencal Supreme
    ROAD: Jamis Zenith, Pinarello Dogma
    Update: part is not available and is dealer only.
    No aftermarket part available unless you want to buy a set.
    Only option is to get one machined or DIY with a wooden block cut in two and the drilled.
    Note this part is needed to adjust e160 & e140 forks
  1. 26mm Shaft Clamp required
    By griffter18 in forum Shocks and Suspension
    Last Post: 03-05-2014, 04:18 PM
  2. Fox shaft clamp: which one?
    By vbm in forum Tooltime
    Last Post: 04-19-2013, 09:11 AM
  3. DHX Air Shaft Hot
    By Swell Guy in forum Shocks and Suspension
    Last Post: 10-25-2011, 10:01 AM
  4. 26mm tyre on one of these rims
    By youthfull in forum 29er Bikes
    Last Post: 09-15-2011, 12:54 PM
  5. Front deRailleur high clamp-low clamp?
    By tinyE in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2011, 09:23 AM
