    Oct 2013
    New question here. 2014 Stumpjumper HT Carbon Comp v 2013 Stumpjumper HT Carbon Comp
    Hi all, long time lurker. I'm normally a road biker but recently moved near the mountains. I've been using an ancient beaten-up fully for a while. I've researched but can't find a significant difference (if any) between the 2014 and 2013 models. Would have been helpful if the manufacturer had a comparison table.
    LBS is offering the 2013 model for CHF2700 ready to take away immediately. Official retail (Swiss dealers expect customers to pay in full usually) is CHF 3149.
    However I now found the 2014 version official price is adjusted down to CHF 3000. Not sure when available.
    Is it worth paying 11% more for the 2014 ?
    XC (PS ... couldn't create paragraphs.)
    Reputation: WR304's Avatar
    There are a couple of significant differences between the 2013 and 2014 Stumpjumper HT Carbon models.
    The 2014 bike has a 15mm thru axle fork whilst the 2013 bike has a standard quick release fork. The 15mm thru axle should help a bit with steering precision and also makes it much easier to remove and replace the front wheel without finding the need to re-align the disc brake calipers.
    The 2014 bike has Formula C1 brakes whilst the 2013 bike has Magura MTS brakes. Personally, I wouldn't want either of those brakes. I'd try to get them changed out for Shimano Deore XT M785 disc brakes and Shimano RT-86 Ice Tech brake rotors from new.
    Apart from that it's just a case of which colour scheme you prefer.
    http://www.specialized.com/gb/gb/bik...carbon29#specs
    http://www.specialized.com/gb/gb/bik...arbon-29#specs
    Oct 2013
    Thanks WR304 for sharing your insight. Good points indeed. I'll hold back for the 2014.
    I have the 2013 Comp carbon and I love it. I haven't had any problems with the 9mm front. If I were to buy a new fork I might opt for it, but not something I just have to have. Favorite bike I've owned.
    The stock brake pads suck (built for longevity from what I was told) but thats a cheap fix. I'm not a fan of their HiLo rear hub. I've had it in the shop twice and makes noise like the bearings are dry, but open it up and everything is fine. I didn't have any plan on keeping them (or most of the stock parts for that matter) so I didn't let it get in the way much.
    Livin' the dream.
  1. Replies: 4
    Last Post: 10-10-2013, 06:50 AM
  2. Replies: 6
    Last Post: 08-08-2013, 03:02 PM
  3. 2013 Stumpjumper comp carbon vs giant xtc composite
    By taod3mon in forum 29er Bikes
    Last Post: 06-27-2013, 10:32 AM
  4. Replies: 3
    Last Post: 06-24-2013, 09:00 AM
  5. 2013 Stumpjumper Comp Carbon Hardtail!
    By toas797 in forum Specialized
    Last Post: 03-02-2013, 12:00 AM
