2014 Stumpjumper FSR Possibilities
For 2013 the Camber and Enduro saw significant changes while the Stumpjumper and Epic were only slightly modified. This may suggest that the 2014 Stumpjumpers are due for a more complete redesign.
Is there anything specific you would like to see on next year's stumpys?
I'm wondering if they may shorten the wheelbase, this seems to be an industry trend with other 29ers being shorter (Giant/Niner for example)
Look forward to your thoughts!!!
650b would be cool, seems like specialized takes every opportunity to bash 650b though. Perhaps just a sales tactic to move 29ers.
From what I've heard, they took every opportunity to bash 29ers too, back in the day. Until they came out with one.
Less talk, more ride...
 Originally Posted by Loll
How about a cabon rear
The S-Works is full carbon and the Expert has carbon seat stays. Only the Comp carbon has an alloy rear. The SJ was redesigned for the 2012 models. It might be a bit much to expect major changes that soon.
2012 Specialized Stumpjumper FSR Comp 29er
2012 Specialized Roubaix Apex Compact
They've been on an "every third year" redesign pattern for a while now though. 08-09, 10-11 and its already been 12-13 on the current generation, so we could see a new SJ in 2014. I'd say 2015 at the latest.
I'd say expect to see 650b in the next design. S-WORKS 650b, EVO 650b, etc. 34 forks being found on most models. 1x11 drivetrains if SRAM brings it down to the X0 and X9 groups.
34's should be a must on all of the trail/AM bikes. I'd like to see a semi-customization program if you pre-order before a certain date. A few color options, maybe a choice of drivetrains (sram or shimano, or x0 vs x7 or xtr vs lx, maybe even a RS vs Fox fork. Carbon rim option. These changes are all off the shelf parts and it would be a pre order deal so you would order the bike and wait 3 or 4 months for them to be built. The only issue with this is the color schemes possibly being the toughest thing to offer.
Just thinking out loud...
-11 Spec. Stumpy FSR 29er
-12 Spec. Epic Expert Carbon
-12 Spec. Stumpy HT EVO 29er
Only thing that stops me from buying EVO is lack of 650b, and going for 650b front only is not enough. I like short CS, low BB and slack HT. I wish they made a chip like Trek has for changing a geometry +/- 1 degree
Throw a cane creek adj. headset on, that shoud take care of your issue.
Yeaaa, but I would like to have it changed in seconds, not minutes, depending on terrain conditions. Whats more, it's ~150$ headset
An all mountain hardtail stumpy would be nice. The stumpy evo ht now doesn't cut it.
And last but not least, ditch Avid brakes, for Shimano or Hope.
Autosag up front and wheels/hubs that will last more than a season.
The arsonist has oddly shaped feet!
XX1 - except it will be XX9 in 2014
P
A 650b Stumpy FSR or 650b Enduro with 150mm at both ends.
Forks:
34mm without a 20mm TA isn't worth the change.
36mm with a 20mm might be overkill.
Rock shocks is on track with the 35mm and a 20mm TA. Now they need to make it in a 29er and 650b.
Remote Brain Dial-in for rear suspension, like already mentioned (by mistake) in the 2010 catalogue.
34 forks would be a welcomed addition. I also like the idea of "lower end" 1x11 set-ups. I imagine both of these have a fairly high probability of happening.
The idea of semi-custom options is one that I would probably utilize if it were to become a reality, but I don't think a company as big as spec would offer such an option. Seems to me like that is easier for a small company to pull off with a more flexible production facilities.
I don't think I could pass on a 650b stumpy should they market one. Although I've heard that the first 29ers were pretty awful, do you guys think there would be a similar learning curve with 650b? Or is it possible that 650b could be an exception because the geometry wouldn't have to be much different than a 26" frame?
Ugh I don't want to wait!
Is there a version for intigrated headsets in a tapered headtube?
I don't see them going 650b anytime soon,they're too committed to 29ers,I guess the big thing for 2014 will be the Enduro 29er and maybe an all new Tarmac. Stumpy FSR will get a major restyle for 2015 maybe.
No more avid breaks please.
Magura or shimano please...
Send from Tapatalk via GalaxyTab
Bring back the XL frame for the 26er stumpy fsr. 2012 was the last year of the XL frame for the 26er fsr. Specialized shouldn't force tall riders to drink the 29er koolaid.
- You may not post replies
- You may not edit your posts
Forum Rules
