• 09-03-2013
    scottyroo
    2014 Specialized Stumpjumper FSR Comp Evo 29 Review
    After a month of being on order from my LBS, this guy finally rolled through the door on Friday. Took it out on a couple of rides and I have some feedback for you all.
    This is a size XL for my 6'3" frame and 36" inseam. It felt big at first coming from an XL Epic but for good reason. The front end is tall to help the rider be in a neutral position on the bike on gnarly downhill segments. It just felt a lot different from the Epic Expert Carbon 29 XL I was coming from.
    My first ride I noticed climbing was a little awkward compared to the Epic I came from (more on this later). The front end is TALL, the stock stem is pretty long, and the handlebars are WIDE. This all made exaggerating the turn a necessity as it took more in the form of turning to get up the technical switchbacks I was climbing. Upon descending, I noticed one thing immediately... the suspension is awesome. I opened it up, adjusted the rebound to fast and switched from climb to descend on the Fox Float CTD and it responded amazingly. I also was a huge fan of the Revelation fork. Very plush and adjustable for climbs and descents. The actuation of the dropper command post is smooth (NO seat wiggle this year either!). For the downhill I did, the middle position was perfect. It was very easy to actuate the dropper on the fly no matter where you were on the trail. Very well placed trigger. The DH section that usually took a lot of body english and effort on the EPIC seemed like a stroll through the park on the stumpy evo. I didn't really push the bike since we were just getting acquainted. At the bottom of the hill I checked Strava and was disappounted to find that I finished considerably slower that my PR I had set for that DH segment on Strava. I knew the bike could be pushed hard and wanted to go faster... it was totally rider error and getting used to the new rig.
    Before heading back up the hill, I wanted to make a few adjustments to achieve a similar fit to the Epic that I felt so comfortable on. First I adjusted the seat position. I moved the seat as far forward and down as it would go. This was necessary especially with the XL frame, the seat tube angle makes the seat angle back more than a M or L size frame. This new position for me helped me still feel "in" the bike (especially with the post dropped) but gave me that sense of control and power of being on "top" of it while climbing. It also helped with my sore taint. I was definitely feeling it from that first climb. Once that was done I went back up the hill. I instantly felt more at home and my taint was thanking me. I crushed my PR on that climb that I set on my Epic! I was shocked. Consider that... with my new stumpy evo, I demolished a PR I had set the week before on a pure XC carbon bike ... needless to say this thing holds its own on climbs. On the second go on the DH section, I PR'd again. Not by much, but as I get more comfortable on this bike I can see that time getting lower and lower. I was still holding it back. The adjustments were spot on. This bike rips once you get a feel for the geometry and make the adjustments you need to.
    GRIPES. The brakes. I did not bed the brakes in like I should have but thought they would be fine given that they weren't the Avids this time around. About half way through my second ever descent on this bike (the PR one) the front brake started a high squeal but still braked well, but the back brake sounded like a donkey in heat and vibrated the whole bike to the point of losing control. I will update the review on this once I get this figured out. I'm going to take it in and have it looked at, but this makes me nervous. The shiftings need to be adjusted on the X9 in the back. Not too sure the kid at the LBS spent a lot of time lining them up. Other than that, its all good.
    Oh, and the Black on black is dead sexy. I'm going to slap some red CB mallet 3's on here next week too. Not that it really matters, but I like looking at the bike when I'm not riding it. :)
  • 09-03-2013
    gfs69
    Thanks for the review, this is one of the bikes that I am considering! (In an XL as well). How does it handle in the tight/twisty stuff?
  • 09-03-2013
    scottyroo
    I've only taken it on a couple of rides and its ok in that stuff. The longer stem and wide handlebars are some parts you could swap out to make those parts more manageable but this thing was made pick a line and bomb. The stability the longer stem and wider bars provide with that in mind serve their purpose well.
  • 09-05-2013
    dowroa
    Good to read. Taking my 2014 Evo Medium out tomorrow with the brakes bedded and the bars cut WAY down! :D
  • 09-05-2013
    foxpuppet
    What brakes do you have and why did you decide not to follow the bed in procedure?
  • 09-05-2013
    dowroa
    The 2014 edit:All Stumpjumpers now have Formula C1 brakes with metallic pads, FTR.
  • 09-05-2013
    scottyroo
    Went out again tonight on the bike. I used swisstop on the brakes to stop the noise and it was effective e but braking power wasn't as good. At least the vibration stopped. Towards the end of the ride the vibration and noise started to come back on harder stops. I will have to keep an eye on it and if needs be get some organic pads.
  • 09-05-2013
    JCL
    Why did you cut the bars down on an aggressive trail bike?
  • 09-06-2013
    dowroa
    Not to derail the OP's post, but the same reason I am 6'0" 225 riding a medium with platform pedals -- preference. I came from a BMX background and I have destroyed my right shoulder. I couldn't physically do a bar that large, and the bike felt like a truck with wide bars.
    Just my choice, and bars are an easy thing to replace/upgrade. I have never been a fan of the "wide bar" movement in cycling. Please note that I personally rode about a total of 100 miles on a combination of demo bikes with 720mm bars on 26/29 Stumpjumpers on Medium and Large frames. I enjoyed the narrower bars on a smaller frame. What I currently ride works well with that configuration, and it is my money, afterall. ;)
    Of course, once I did that, and I was able to manual the bike, I was pretty happy and felt at home (surprisingly on a 29!). :)
    My local trails are not in the mountains, in Central NC. I do have access to some very nice mountain trails within a relatively short drive and lots of great local trails. For me, personally, the Evo is a "do everything" bike, and I think it will do that well. :)
    Ps. I will promise you it will be ridden aggressively on the trails, however! :D
  • 09-09-2013
    Venturawoot
    Thanks for the thorough review! Sounds like a great bike. I'm ready to buy a new carbon bike and this one is one of 4 I'm seriously considering. I had the first ever 29r stumpy and really didn't like it. My feet would hit the front wheel quite frequently in turns and pedal strikes were very common. I figure that by now those problems should have been worked out?
    The other 3 bikes I'm considering are the Ibis Mojo HD, the New Santa Cruz Solo, and the new SC Bronson.
    I'm not a crazy kid anymore so I don't jump too much or take crazy risks on the way down but I do like a plush suspension. Feel like my 06 Enduro hurts me too much on the way up so want to maybe tone down the travel a bit and go with newer technology.
    Really like the idea of having a Santa Cruz bike but they sure are not cheap. All I've heard are great things about the Ibis but not sure where to get one yet. My cousin owns a bike shop down south a couple hours and can save some dough on the Stumpy through him I'm hoping. He can't get the SC and doesn't deal with Ibis. Just want to make sure I don't rush into things on a big purchase like this.
    Haven't been able to find a place yet to test ride ant of these bikes. Any advice would be appreciated. Thanks in advance.
  • 09-09-2013
    dowroa
    I would not assume the pedal strikes are gone. Something that Specialized really prides themselves on is a really low BB height. They state with the low BB, it makes you have a lower CG and feel better in the corners.
    From my experience on two Specialized bikes that I ride, pedal strikes can and will happen if you get lazy, tired, or are not used to it -- Evo or my older bike.
    As for foot contact with the tire, I have no issues with that. I ride with my brother who has a 29L Kona that I will foot strike the front tire. However, on my 29M Evo, that has never been an issue for me or him.
    To your other bikes, I apologize, but I have no direct experience with those bikes.
    For the Evo (non carbon, although I did ride one), I did ride a lot of the Comp FSR before i bought this bike, and quite honestly, I think the FSR is a really good basis for comparison. The only major differences this year are the changes to the brake levers in feel/adjustment/integration with shifters and the fork which is now a Rock Shox with a Maxle (which I am personally not quite fond of the design).
    As far as use case, the things I personally liked on the 29M that I brought to the Evo 29M I bought worked really well. The bike feels very stable and I have no real complaints.
    Personally, I can't really figure out what the front compression setting really changes, as it always feels the same at low speed to me, and I am not crazy enough or have played around enough to compare the high speed differences. With that, it still functions well. I just can't tell with the setting at partially open or fully open a ride quality difference at low speed. The rear shock seems to be the most plush, to me, in the trail setting (surprising for me). The dropper post....I didn't really know what to expect, but with the height labeling on the post, it makes it really quick to dial in the right height. That and the fact it works well in action is really nice, even though I was unsure if it would be useful. I found when I went back to my older Specialized, I missed that feature for longer, technical rides (10 miles+). It really shines for me so I can keep my legs in alignment and stretched out on climbs, and then get the seat out of the way on the fast sections.
    If I had one piece of advice, it would be to get on as many bikes as you can, no matter what. I paid to do so, and it was completely worth the time and hassle in getting a bike I really felt "at home" on. Being comfortable on a bike is a big deal for me, and having bought one that I had high confidence in is a real treat. Now, I can just concentrate on riding, and not really worry about the bike, which is what I prefer. When I start being limited by an item, I can work around or "upgrade", such as the 2Bliss tires on the bike to a functioning tubeless system.
    I would like to investigate the rear brake more, as I am not sure if I have it bedded in correctly, but it is very honky/vibraty for me. More to come as I get more miles. 24.7 miles on this Evo, thus far.
    Overall, for myself, I find the Evo to be a really good selection as a "do everything" bike. I would feel really comfortable taking this bike to a rock garden, Ashville NC for some real mountains, and some light downhill work. I haven't really given it anything it can't take as an All Mountain bike and, at at this point in my life, I don't really see myself jumping it per my BMX past.
    If you have any specific questions, I am more than happy to answer, and really happy with the bike!
  • 09-10-2013
    scottyroo
    After using Swisstop on the brakes, the vibration and honkiness is back for me after re-bedding them in. I'm going to make it a point to keep the rotor clean with rubbing alcohol over the next few rides but that is the only gripe I have had with this bike... the rear rotor noise/vibration.
    Thanks for the great follow up! I agree with you on all points... pick a bike that you feel comfortable in and matches your riding style.
  • 09-26-2013
    Psychout
    Scottyroo - I wanted to share with you my experience since owning the 2014 Specialized Stumpjumper FSR Comp EVO 29 a week ago. I had the exact same problem as you describe with horrible rear brake vibrations. I took it back to my LBS only to have them clean the brakes and then they seem OK under light to medium braking.
    I took it out to the trail immediately that afternoon only to be upset again with the rear brake vibration, right into the frame return again.
    My LBS was fantastic at getting right onto this issue by calling Specialized first thing that Monday morning. It seems like it is a resonance issue / design fault with the seat stay and it requires an S-Works Carbon seat stay to replace the aluminum one. Specialized FEDEX'd the seat stay out (of course all under warranty) immediately and it was on my bike 2 days later.
    I haven't yet hit the trails today, however I can tell immediately by riding the bike down the street with hard rear braking that is resolved the issue completely. You can also tell by just walking the bike and apply full rear brake pressure the bike doesn't vibrate / jump / chatter.
    Buyer beware though on this bike...this is a major screw up on Specialized's behalf, either a big manufacturing issue with the first batch or they didn't bother thoroughly testing the Aluminum frames.
    In saying this though...Specialized's warranty service is 2nd to none...they wanted to get the problem resolved and make it right. This bike is fantastic...best choice I made after many demo days.
  • 09-26-2013
    scottyroo
    Thanks for sharing! I had all but given up. I tried steel wool to no avail and had not heard about the seat stay. I'll check it out with my LBS
  • 09-26-2013
    dowroa
    Please reply when you get a chance to ride. I am still having rear brake problems, and I would like to get my LBS on it. They told me just to ride more, but after 50+ miles, it isn't going away.
    - brian
  • 09-29-2013
    Psychout
    - brian
    Hi Brian - ok I spent a solid 4 hours on some very technical trails today with lots of fast downhills. Great news - problem solved 100%. No chattering, vibrations, etc under absolute slamming the rear brakes. Just nice smooth modulation. These Formula C1s are actually very good brakes.
    Just a little bit of front and rear brake squeaking but thats solved by a quick wipe down of the discs and they are perfect now.
    Tell your LBS to go call Specialized warranty support...I have no idea why LBS's are resisting to fix this issue and Specialized are extremely helpful in resolving any issues. Specialized know exactly what the problem is and the solution.
    Good luck and let me know how you guys all go!
  • 09-29-2013
    Psychout
    Scotty - how did you go with your LBS? Are they working with you on this?
  • 10-04-2013
    Psychout
    Any update on this guys? Was interested to hear how everyone else went with Specialized and their LBS?
  • 10-11-2013
    Edwards82
    Hi. I bought a 2014 stunt jumper a couple of weeks ago and the back brake squeals when applied. Iv done over 40 miles on it. I thought it was just the brakes bedding in. I was looking to buy some new pads and stumbled on to this forum. Do UK stunt jumper differ from the US version? I approached the bike shop I bought it from. They phone specialized who said they had never heard of the problem. On the stunt jumper from 4 years ago but not on the current model. Is there anybody from the UK experiencing this problem?
  • 10-14-2013
    Psychout
    Just sent you a PM. You do mean the Stumpjumper not "stunt jumper" right?
    This is a known problem by Specialized USA...you need to get the LBS to encourage Specialized UK to contact the USA guys are they are getting more complaints on this and now have a fix. My guess it was a manufacturing defect in the seat stay.
  • 10-14-2013
    Edwards82
    I meant the Stumpjumper.
    Cheers for the info. I'm booked in at the LBS tomorrow. I will try and get them to contact Specialized USA.
  • 10-24-2013
    rtBiker
    Hi Lads
    Thanks for all your input, Scottyroo great review! I have just ordered my SJ Comp Evo 29 here in spain, I have to wait til January but happily pass the time reading reviews an looking at pics here. Changing from a Sj Comp Carbon 26.....hope I wont miss the carbon!
  • 11-04-2013
    Edwards82
    Has anybody had any problems with the command post losing air pressure? I have had a heavy weekend riding and the seat post has stopped working. I have charged the post but it works for a bit then loses the pressure. On the plus side Iv got Specialized UK to agree to change the rear seat stay for the carbon version. For a brand new bike I can't believe it has so many problems.
  • 11-05-2013
    Bigb2000
    ^. I love my fsr evo, but yep, problems with bottom bracket, dropper post, and broken star nut but gets aggravating.
  • 11-11-2013
    runfast
    What issues have you had with the bottom bracket?
    I took mine out for its first ride this weekend and I had the same braking issues with the rear brake. I also noticed that there was some kind of squeaking noise that I could not pinpoint where it was coming from, and I was trying to consistently replicate movements to pinpoint it but it seemed like sometimes I would get it to happen while I was pedaling and also some while I was not. I am fairly new to the sport and just transitioned from a 2012 Carve because I wanted a full suspension ride to reduce lower back tightness that I was getting on the hard tail. I never had any squeaking on the Carve, which leads me to think that I shouldn't be hearing this on the first two rides of relatively easy 7 mile trail.
    Also I noticed that my lower back tightness was not near as bad as on my old bike, but I was feeling it a little. I borrowed a guy's Trek superfly 100 for a 35-40 mile pretty tough ride last weekend and I didn't have any back tightness. I think that I need to play with my position on the bike. Do Y'all have any suggestions?
  • 11-11-2013
    lowayne
    That XL makes those 29ers look a bit smaller! Thanks for the brake noise info Psychout. I just ordered my SJ Comp Evo 29er, I'll report back if the issue has been resolved mid production run by Specialized.
  • 11-14-2013
    Bigb2000
    I have gone through three bottom bracket bracket bearings in 500 miles this year. Currently have an Enduro brand now. Will see if it will last longer than stock. If you're getting noise, see if crank has side to side play. If so, the plastic preloaded on left side of crank needs to be tightened. I use a hammer and screwdriver to tighten. Turn preloaded clockwise until no more play. If crank goes up and down, probably bearings bad.
  • 11-23-2013
    Vevo
    Hi guys just got my stumpy 3 weeks ago and yes I have the same issue with the rear brake vibration. I'm in South CA and my LBS guys are awesome here @ Montrose Bike Shop. I noticed it on the very first ride, actually on the test ride. I talk to my LBS guys and right away they contacted specialized. So at first specialized told them that they were going to replace the entire rear suspension to carbon, but now specialized told them to replace the entire braking system to Shimano XT. And if that doesn't solve it then they'll go ahead with the suspension. I'll keep u posted hopefully done with my bike today
  • 11-23-2013
    Jamie_MTB
    i thought if you removed the plastic clip on the rear triangle this fixed it?
  • 11-23-2013
    JACKL
    Make sure the top collar is tight by trying to turn it clockwise (when looking from above).
  • 12-05-2013
    socalrcer
    Just picked up a new FSR Comp last week. Took the time to do the break in procedure for the C1's (50 sprint and stops) and they worked great on the first trip. First impressions on the brakes was they don't grab as hard as the SLX's on the Elite I tested, but they are more linear. No noise either. Bike is incredible, and Rock and Road through in the dropper which worked perfect, thanks Chris and Brian for the help. Had to do the auto sag twice to get the setting right, think I was on a down slope on the first try and it set it too low. Now I need to dial in the rebound, started on the slow side, going to speed it up this weekend weather permitting. Went with the side facing bottle holder from specialized, which helps in the tight space, even on a large frame.
  • 12-13-2013
    rtBiker
    Post a pic Socalrcer!
  • 12-17-2013
    rob1208lv
    Is this Brake issue only in the Comps? or does the experts evo fsr's also have this issue?
  • 12-17-2013
    kev.1n
    Is this a problem found only in the 29er version? I'm about to receive a 2014 in the mail but its the 26 inch version. Curious to see if this will happen. I will definitely take the time to bed in the brakes properly to try and prevent this
  • 01-10-2014
    C Willsy
    Same thing happening here in Oz - had my Stumpy now for about 6 weeks and same noise/shudder in the rear - took it in to LBS and they were fully aware of the problem (said they had already had 3 other people come in with the same symptoms) - they were very helpful and as a temporary fix swapped the 180mm rotor to a 160mm and said they would contact Specialized and get the new Carbon part on order (only down side, it may take up to 6-8 weeks)......
  • 01-11-2014
    paparotus
    i have a 2014 expert 29 evo,no problems with the brakes or weird sounds(avid 7 trail big improvement over the avid 5 r from last year),but i have to say that i had last yearīs 2013 stumpy 26 evo comp and with that bike i had some brake issue like gobbling sounds.
  • 01-11-2014
    lankyspark21
    just picked up my 14 fsr comp evo today cant wait to ride it tommorrow
  • 01-13-2014
    Kabob King
    I have been riding my 2014 stumpy comp evo 26" for about 3months now. I also had the brake vibration issue and took it to the bike shop I bought it from in Pasadena can and they said they did some work and fixed it. I took it out to the parking lot and in three tries was able to produce the same vibration issue.
    I then did what I read on the forums...which was so unscrew the screw holding the rear brake cable to the chainstay and the prob was solved.
    The brakes are decent, not a lot of bite or power but smooth and quiet
    Funny thing is my friend has the same bike but the 2013 model and does not have this issue. Im assuming the formula brakes produce lots of vibration or something is different in the manufacturing of the frame.
  • 01-17-2014
    rtBiker
    Well my LBS has come up trumps, they said january and here it is! Finally got my 2014 Evo 29 and itīs amazing! My only complaint is I find the front plate a bit small, am going to put a 36 on.
    Attachment 863071
  • 01-17-2014
    JCL
    Attachment 863071
    Yep go with a big plate.
  • 02-03-2014
    peterhenric
    Attachment 867082
    Took delivery of my '14 SJ FSR Comp EVO 29 in mid December and am absolutely loving it and wanted to give you all my 2 cents but I also wanted some input from you all on a few things.
    The brakes: Initially the brakes were absolute garbage as they were super squishy and were very under-powered. After adjusting the reach out on them and getting a couple rides in they seem to have decent power now but I still have to squeeze them about half way in before they start to actuate. Is this normal? I took them in and after a month and a half Formula is finally starting to warranty them. Apparently there was a faulty o-ring or something so we'll see if they are any better when I get them back. Let's hope so. That being said, I haven't had any problems with any vibrating or noise coming from either end.
    The "auto-sag" seems to be more of a gimmick than an actually usable thing. The auto-sag should work properly regardless of how much I weigh but it keeps setting it too soft. I made sure that I pumped it up 50psi above my 200lb weight but it keeps going too soft. I ended up putting an extra 20 psi in there and it seems to be much better.
    Has anyone considered putting a shorter stem on there? I've got one buddy who says that doing so is a bad decision as Specialized chose that length for a reason. He says that if you shorten the stem then you'll need to move the seat back and that's going to negatively affect the handling/climbing abilities of the bike. I've got another buddy who thinks there's nothing wrong with it at all. Just whatever feels good...
    Reason why I'm thinking about getting a shorter stem is on steep downhills (even with the dropper post all the way down) I still feel like I've got a little too much weight over the front end and it's a little sketchy. How say you all?
  • 02-03-2014
    Kabob King
    Dont think its an issue running a shorter stem I know lots of people that make the change. Front end may feel a little less stable on climbs.
  • 02-03-2014
    bad andy
    Go with whatever stem length is comfortable for you. Tell buddy one he is wrong and owes buddy two a beer.
  • 02-04-2014
    stumpynerd
    Pickup a couple of dirt cheap stems from your bike shop. Test to see what works best for you then order a nice stem. I got an xl and im running a 70mm stem. I got a syntace megaforce 2 stem, even comes with ti bolts! I can tell the difference in stiffness from my stock stem.
    Attachment 867233
  • 02-06-2014
    peterhenric
    Attachment 867233
    That's a good idea. The stock stem is 90mm and "buddy 2" is telling me to get a 35mm stem which seems really short. I was thinking more along the lines of a 50(ish)mm stem but didn't want to get one and realize it either was too short or not short enough.
    I'm 5'10" and have a large frame.
  • 02-06-2014
    Jamie_MTB
    I started with a 50mm stem but I'm now running 35mm. The steering is much quicker with the 35mm, switchbacks/tight spaces are easier and the front end has more pop. The only downside so far is the front end has jackknifed a couple of times when I've lost it going into tight muddy bends.
  • 02-06-2014
    peterhenric
    Thanks for the input.
    My reservation is that the bike is perfect at all times other than steeper downhills so I'm worried that it'd get too light at other times. I'll probably start with a 50mm and go from there so that it's not such a huge change.
    That being said, have you gone with wider bars than what comes stock? The wider bars would kind of adjust for the shorter stem, right?
  • 02-06-2014
    peterhenric
    Pardon my ignorance but what's a front plate?
  • 02-09-2014
    peterhenric
    Has anyone looked at trying to figure out a way to re-rout the shifter cables out from under the bottom bracket? I hate that it is routed the way it is.
  • 02-10-2014
    rtBiker
    the plate is the chainring.
