Results 1 to 16 of 16
    Reputation: JAY55's Avatar
    Mar 2012
    2014 S-Works Epic WC White
    Anyone got the epic s-works wc in white? Planning to order one, LBS told me not available for couple months.
    ________
    12' BMC Fourstroke FS02 XT
    11' Epic S-Works XX
    13' Epic S-Works XX1
    14' Epic S-Works WC XX1
    18' Yeti SB5 Turq
    Reputation: CarManDSL's Avatar
    My white frame is supposed to be delivered end of January in Canada.
    All SW Epic WC sold out in Canada, all before 1st one even delivered! Specialized Canada never orders enough, hence most everyone I know that has a previous SW Epic model year, got theirs in the US, including my 2011.
    You'd think Spec Canada would have figured it out by now!
    17 990 Element BC Ed - 25.5 lb burly
    15 Enduro Expert 29, SW build - 27.6
    14 SW Epic WC - 21.8
    12 Niner Air9RDO -16.4
    I've got mine absolutely gorgeous!
    make with the pix.
    Quote Originally Posted by tahic View Post
    Here's mine, had it for a little over a month now.
    Quote Originally Posted by ryanhugh View Post
    make with the pix.
    Attached Thumbnails Attached Thumbnails 2014 S-Works Epic WC White-bike-1.jpg
    Bob, frame size and weight?
    Yup. Gorgeous!
    Thanks, it's a large frame and weighs 21.4 pounds as pictured with pedals, cages and Fast Trak tires on front and back.
    Quote Originally Posted by CarManDSL View Post
    Yup. Gorgeous!
    Feb 2007
    Nice, but your weight doesn't match up with my black bike. You have a heavier rear tire, heavier cranks, heavier brakes (I think), and yet I'm 21.6lbs for a large....
    2015 Fat Boy Pro HED carbon wheels
    2012 S-Works Stumpjumper FSR
    Delta 7 Ascend Road bike ENVE wheels
    Don't know what to tell you, I guess you think I was making up the weight of my bike? I just went out to my garage and took a pic, maybe my bike is just better than yours . I'm pretty sure the 2014 Formula R1 brakes are lighter than most everything else, but I could be wrong its happened once before. Oh, that was with the multi tool removed from the top tube.
    Quote Originally Posted by rdalcanto View Post
    Attached Thumbnails Attached Thumbnails 2014 S-Works Epic WC White-bike-pic.jpg
    Feb 2007
    Nice! Your scale is probably more accurate than mine. I too had a white on order, but caved and got black because I got tired of waiting. Do you think the Ritchey bar and stem is lighter than stock?
    Reputation: albertdc's Avatar
    Re: 2014 S-Works Epic WC White
    Quote Originally Posted by Bob_Lablaw View Post
    What saddle is that? Carbon rails? That may be part of the weight savings there...
    Sent from my SCH-I545 using Tapatalk 2
    These scales seem a little random, between mine, my brothers and the bike shop they all give a slightly different weight.
    The bars and stem are pretty comparable to each other weight wise. I think the biggest difference is probably in pedals and the seat. The EB 11 pedals are over 100 grams lighter than the 3's and I think a carbon railed seat is around 30-40 grams lighter than a ti railed.
    There could be other minor things like grips and misc titanium hardware or how much Stans is in your tires.
    Feb 2007
    Aside from some "scale variance", I wonder if the white weighs a little more than the gloss black.....I know when I was at the lbs the other day, I saw a white S frame (not a WC) that had a chip out of the headtube and it looked really thick.
    Feb 2007
    Quote Originally Posted by cpritch07 View Post
    Anyone been able to weigh both the "black" and "white" color schemes (in the same size) to see if there is a weight difference?
    what´s the bottom bracket parts?pix as well pls tks!!!!
    BB Bearing Replacement for 2014 S-Works Epic
    I had replaced my crank with 170mm S-Works and the shop did it. As far as I know they didn't change the BB.
    I'd like to replace my BB bearings but it seems the cups are not user serviceable? There is a stop at the back of the cup which kind of eliminates the ability to tap the bearings out. It seems you can only tap the whole cup out? Any idea on this? I cand find info anywhere.
    On top of that it would seem that one bearing is slightly different in size, and I only ascertain that by looking at the crank axel. So I'm not sure even what size to get. I didn't think it was GPX but mybe it is? The stock says it's PF30, and that seems to be what it is except for the possibility that the bearings are a bit different.
    I'm hoping I can service this myself. I've packed or replaced the bearings a few times in the miles I've put on the bike, at different shops around the country and the amount of miles I'm doing I really need to be able to take care of this myself. I wish I'd taken photos when I last dismantled it. I will next time but hope someone knows what I have and whether I can get replacement bearings or need to replace the BB, and which ones to get in either case? Tks
  1. 2014 Specialized S-Works Epic Arrivals?
    By 2k13458 in forum Specialized
    Last Post: 06-27-2014, 03:51 PM
  2. Black or White S-Works Epic WC?
    By rdalcanto in forum Specialized
    Last Post: 11-27-2013, 06:09 PM
  3. 2014 S Works Epic
    By kiwiktm in forum Specialized
    Last Post: 11-27-2013, 02:43 PM
  4. Paid Spam: 2014 Specialized S-works Epic.
    By cdsdad in forum Specialized
    Last Post: 11-19-2013, 01:21 PM
  5. Who's ordered the 2014 Epic S works WC?
    By patrickrl32 in forum Specialized
    Last Post: 10-27-2013, 07:51 AM
