Results 1 to 16 of 16
    Reputation: rcjonessnp175's Avatar
    Aug 2010
    2014 Fox FLOAT X CTD-ADJ Kashima Factory Shock fit on stumpy evo expert?
    As the topic asks does anybody much smarter than me on shock sizes know if this will fit on the 2012/2013 stumpy evo experts? Rumor is they are available may19. Thinking this will be an awesome rear shock for the riding I do here in Colorado.
    May 2005
    Won't fit without some sort of aftermarket wishbone shaped yoke or some machine work being done to the Float X shock to fit the wishbone.
    Aug 2010
    No kidding? That's a big bummer
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    Might be able to swap the shaft from your current shock onto the Float X so you have the proper clevis mount.
    14 Aurum, 16 Fuse, 17 T130
    Aug 2010
    Right on. Buddy of mine who's a pro and such has emailed fox to inquire about this shock on this bike, no answer yet lol. I wouldn't be surprised if specialized outfits this shock on evos and enduros next year. Can only hope I guess.
    Mar 2013
    Specialized have a lot to answer for with the proprietary clevis - they need to back it up at cost - or else lose [my] custom
    Jun 2010
    They run that clevis on nearly every FSR bike now. It really does help stiffen the rear end up quite abit, but ti does limit our options.
    I saw this online the other day. Not a stumpjumper but it's on an enduro. There is hope!
    2014 Fox FLOAT X CTD-ADJ Kashima Factory Shock fit on stumpy evo expert?-s1600_scott_papolas_specialized_s_works_enduro_29_se.jpg
    Reputation: Znarf's Avatar
    As far as a conversion went. I asked MOJO (british distro) about that - they didnīt knew it back then for sure. But they were optimistic.
    I also donīt really like the clevis mount, but I have to say - on my 2011 SJ FSR the shock eyelets really DO hold up.
    Most bikes I owned before ate through bushings like warm butter.
    Jun 2010
    I put over 2000 miles on my 2011 SJ Elite and not once did I have to replace anything on the shock. My buddy with a 2012 Giant reign has replaced the bushings twice in less than 500 miles.
    Forget about the fox stuff...I want to see a custom ohlins / specialized air shock for the enduros and stumpys. Anyone else?
    NO! =)
    Remember the AFR? And the E-150 - they werenīt so rad. Not bad, but not really great either.
    I want after market stuff. Non proprietary, so I can upgrade and replace in four years still.
    The current stuff works good enough for me though...
    neariahgil
    Aug 2010
    Guess I'm not the only one with rear shock issues & thought of a similar solution.
    2012 Stumpjumper FSR EVO 29er
    Just set it up today, haven't ridden yet, but it looks and feels awesome. Can't wait to give it a try.
    Did have to slightly "modify" the upper shock mounting bracket, to make top of shock clear.
    Can provide any other info, if anyone would like to know.
    Happy trails,
    gil
    Attached Thumbnails Attached Thumbnails 2014 Fox FLOAT X CTD-ADJ Kashima Factory Shock fit on stumpy evo expert?-20150828_154607.jpg
    ^^^Nice!!!!
    hvc
    hvc is offline
    Quote Originally Posted by neariahgil View Post
    Happy trails,
    gil
    Hi,
    Very nice setup you got there. Please share your mod, i'd like to try out on my 2014 Stumpy.
    Thanks.
    Reputation: madmark's Avatar
    Most shock aftermarket companies run the Specialized strut fitting in there range now.
    Fox
    Rockshox
    Cane Creek
    Ohlins
    Home trails Swinley Forest UK
  1. 2014 Stumpy Spy Photo!
    By stumpynerd in forum Specialized
    Last Post: 04-02-2013, 06:35 AM
  2. Replies: 0
    Last Post: 03-09-2013, 08:43 AM
  3. Stumpy Expert Carbon FSR - shock topping out
    By crankspd in forum Shocks and Suspension
    Last Post: 07-14-2012, 04:32 PM
  4. Need Help - Fork Float 120 FIT RLC Kashima or Not Kashima coat
    By rusly in forum Shocks and Suspension
    Last Post: 03-29-2012, 12:47 AM
  5. Replies: 1
    Last Post: 06-13-2011, 02:23 PM
