Results 1 to 8 of 8
    Mar 2013
    2014 Epic comp size..?
    I am 5'10 at 195lbs, I am not sure if I need a medium or a large. I currently ride a medium stumpy ht, no bike shop around has a 14 epic I can test ride.
    Feb 2013
    I'm 5'10 and rides a 2014 Epic Comp in size medium. It works for me.
    Reputation: sgtjim57's Avatar
    Depends on inseam.
    2017 Cannondale Scalpel Si Carbon 3 (27.5)
    I'm 5'10" and am on a 2013 Comp medium. I'm between large and medium sizes, but I have longer legs and shorter torso. My upper body is sized for a medium and my lower body is sized as a large. I find the medium is a good fit with a 110mm stem. It handles quite well but sometimes I feel like I could use just a tad more reach.
    Well, I'm riding a Large epic, and I'm just below 5'10. I like the riding position and as I'm running a 90mm stem it doesn't feel that stretched. Hope it helps.
    Reputation: EPICYZ's Avatar
    5'10" has typically been the cut off between medium and large. The '14 is a bit longer so I would bet a medium will be the ticket. Test ride to make sure.
    2016 Yeti SB4.5c
    2014 S-Works Epic WC
    Jul 2014
    I'm the same size as you 5'10" and 185lbs, I test a M epic comp carbon of 2014, I'm not sure and I can't test a large size.
    I'm going to buy the m5 version, epic comp 2014.
    which size you bought?
    5-10 and a half,ride a medium,my trouser leg is 32 and my cycling inseam is 34.Thats a 2013 epic.
    2013 epic comp
    2013 supersix evo
  1. Replies: 56
    Last Post: 06-27-2014, 10:16 PM
  2. Replies: 4
    Last Post: 03-09-2014, 04:49 PM
  3. Replies: 4
    Last Post: 03-08-2014, 03:31 PM
  4. 2014 Epic Comp Carbon Front Derailleur Issues
    By Rocketman88 in forum Specialized
    Last Post: 01-03-2014, 07:58 AM
  5. Going tubeless 2014 specialized epic comp
    By Boothy82 in forum Wheels and Tires
    Last Post: 11-28-2013, 04:15 AM
