Results 1 to 7 of 7
    Jan 2011
    2014 Enduro Comp 29er - Your Fork Settings
    I am looking for some direction with the new Pike Fork as mine seems to be too harsh and not sure which way to adjust.
    I am currently running just over 25% sag with 12 clicks out from slow on the rebound.
    What are you running?
    Reputation: titusquasi's Avatar
    That sag is similar to what I am using...I think. I typically set my rear shock very precisely, initially set the fork to around 5% less sag than the shock, and then fine tune the fork to match the "feel" of the rear shock.
    I should probably check my current sag. I came down 10-15 psi in the fork from my initial setting. This was to match the feel of the rear shock (rear around 27-30% sag). The Pike is very "soft" in the top of its stroke and may fool you into thinking you have the air correct when it may be a bit too high...just my theory. Once I came down on the air pressure I was bottoming just a bit too much. I added an extra token (went from the factory 1 to 2). That was too much progression so I cut a token in half and 1.5 tokens feels pretty good on bottom resistance.
    In this colder weather I am only using +2 clicks of compression. I'm not sure where my rebound is as I just set it to match the "feel" on the rear. Things were a bit too bouncy initially so I increased rebound in the rear a bit as well as the front.
    I'm not sure if my rambling is helpful... My experience with the Pike is it is a very smooth and sensitive fork. You probably know but things that can affect harshness is too much air, too much compression, and too much rebound. I guess you could just play with one variable at a time to do some experimentation.
    Jan 2011
    Thanks for the reply,
    Mine doesn't have the compressing setting control as mine is a comp and did not come with that version of the PIKE fork
    How many clicks of rebound are you running?
    You do have a compression setting. It is on top of the right side. You do not have a low speed compression setting. I have mine set to 4 clicks from full open. Rebound I also have at 4 clicks from wide open. Pressure is set to 51 psi for a 200 lb rider weight.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Salespunk View Post
    Actually, it IS a low speed compression adjuster.
    Jan 2011
    Thank you for the help; I will adjust my settings tonight and see how it rides tomorrow.
    Dec 2013
    Quote Originally Posted by titusquasi View Post
    What is a token?
  1. 2014 Enduro 29 Comp SE
    By jmeldrum26 in forum Specialized
    Last Post: 04-09-2016, 05:02 PM
  2. 2014 Enduro Comp 26
    By hookster in forum Specialized
    Last Post: 02-23-2014, 12:49 PM
  3. 2014 Remedy 8 29er or 2014 Enduro 29 comp
    By mo6500 in forum 29er Bikes
    Last Post: 12-04-2013, 07:04 PM
  4. Replies: 32
    Last Post: 12-01-2013, 12:04 AM
  5. 2014 Enduro Comp FSR 26 - Pics and Specs
    Last Post: 11-04-2013, 08:56 AM
