Results 1 to 2 of 2
    Jun 2013
    2014 Chisel fork on my 2013 RH Comp?
    Does anyone know if this would fit? Or if it would fit easily, I should say?
    Specs are here:
    -Uni-directional carbon monocoque structure with carbon legs, carbon crown, and carbon steerer
    -Integrated alloy crown race
    -Alloy dropouts compatible with SBC OS28 end-caps
    -PM 160 brake mount
    -Suspension-corrected 480mm axle to crown
    -47mm offset
    It would replace the stock XC28 fork.
    Reputation: RS VR6's Avatar
    As long as your 2013 RH has a tapered headtube. You might need a lower bearing too.
  1. Replies: 19
    Last Post: 04-09-2014, 11:03 PM
  2. Chisel fork anyone ? Can't seem to locate any... :(
    By JoeOxfordCT in forum 29er Bikes
    Last Post: 09-01-2013, 05:38 AM
  3. Replies: 6
    Last Post: 08-29-2013, 02:43 PM
  4. 2013 Stumpjumper Comp or 2014 Crave Pro ?
    Last Post: 07-26-2013, 11:22 AM
  5. Replies: 3
    Last Post: 05-13-2013, 06:34 PM
