Results 1 to 7 of 7
    ride your bike
    Reputation: jubilee's Avatar
    2013 stumpy evo 26 Pike upgrade?
    I am looking to upgrade the stock revelation to a Pike soon. Just realized the 2013 rev has a 20mm maxle and the pike has 15mm. Is there an easy way to upgrade to the pike without buying a new hub?
    Thanks for any help!
    Taking it easy for all you sinners.
    Reputation: WHALENARD's Avatar
    Feb 2010
    What hub do have? Typically you just need new cups for your hub.
    ride your bike
    Not sure...whatever hub came stock.
    Feb 2010
    Not sure what the stocks hubs were. Bring it to your bike shop (only place you can get specialized specific parts anyway) and they can tell you straight away if there are 15mil adapters for your hubs or not. My guess is there are as spesh specs bikes with both 15mil & 20mil axles
    ride your bike
    Thanks, I hope it's that easy.
    Quote Originally Posted by WHALENARD View Post
    Being a stock stumpy, chances are you are running roval hubs, just get the end caps for the hub for 15mm and you are sweet. $40 fix.
    Feb 2006
    I grabbed a set from my LBS months ago when upgrading fork to a unit that had 15mm TA. I'll see if I can get the part# off the bag for you.
  1. Carbon 29r Stumpy w/150mm Pike?
    By renderedtoast in forum Specialized
    Last Post: 08-24-2013, 09:27 PM
  2. TFTuned RS Pike Push upgrade = Way overpriced
    By Sgt-MonoLinkrijder in forum Shocks and Suspension
    Last Post: 06-23-2013, 08:01 PM
  3. RS Pike 327 (Coil) Damping upgrade options
    By flaminx0r in forum Shocks and Suspension
    Last Post: 05-28-2013, 07:02 AM
  4. Looking for an old post on the RockShox Pike 327 forks upgrade
    By Crzpete in forum Shocks and Suspension
    Last Post: 07-03-2012, 11:13 PM
  5. Replies: 5
    Last Post: 05-05-2011, 05:43 PM
