Results 1 to 2 of 2
    Jun 2005
    2013 S-Works Epic SRAM - can you put on a ft der?
    Hi,
    Considering purchasing a 2013 S-Works Epic Sram, but I wanted to know if you can put a ft der on that frame. I have not yet ridden a 1x11 since my stolen S-Works was an '09. I loved that bike... Anyway, I may just get the '14 with XTR, can't go wrong I assume, as insurance will cover it, but curious about the Sram. Thanks.
    old fart
    Hard to know what you are asking for. Can you mount a front derailleur to an 2013 SW SRAM (1x11 model)? Yes, you need a bottom pull Direct Mount Spec 3 SRAM front derailleur. And you require the Specialized adapter for the derailleur that mounts it to the chainstay.
    You will also need the XX or SW crank, and the 10-speed chain & cassette. Probably better to just ride 1x11 on your usual terrain as see how you find it.
    I would probably be there on my own SW except that the cost of change, allied with the amount of spare 10-speed cassettes, chains and rings makes the change very expensive.
  1. 2013 S-Works Epic SRAM
    By PanuV in forum Specialized
    Last Post: 10-11-2013, 08:22 AM
  2. Replies: 0
    Last Post: 03-16-2013, 05:24 PM
  3. 2013 S-Works Epic SRAM
    By ttusomeone in forum Specialized
    Last Post: 10-05-2012, 05:21 AM
  4. 29er Epic S-Works - xtr vs sram
    By uzj100 in forum Specialized
    Last Post: 08-15-2012, 06:46 PM
