Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 85 of 85
  1. #76
    367g
  2. #77
    Reputation: WR304's Avatar
    Quote Originally Posted by WR304 View Post
    Extralite offer a 142x12mm rear hub but no Sram XX1 freehub option.
    Quote Originally Posted by MarcoL
    I prefer a lightweight carbon rim than a lightweight aluminum rim at the same weight,
    It is not very easy to decide which one is best, since if you broke the wheel you will broke some bones
    Which one do you think is best? The one on /r2 or the extralite?
    Although it's not listed on their website wheelset page when you go to the website hub page Extralite do have a Sram XX1 freehub now.
    Extralite HyperRear
    Extralite are one of those companies that I always have mixed feelings about. Their parts are some of the lightest around but that weight saving comes at the price of longevity. Things like the threads that allen bolts screw into are pared down so you only have a few turns available. The threads in my (2009 vintage) Extralite stem were looking close to stripping, which is another reason why I replaced it. The Extralite brass coloured parts are light but that metal is very soft. Where it's used for any sort of threads or allen bolts you have to be careful.
    I bought an Extralite Ultrastar2 headset expander and that was terrible. It didn't clamp tightly enough in the RockShox steerer to be able to adjust the headset bearings, and then to finish it off the 8mm allen bolt rounded. I had to hammer it out of the steerer tube. At the same time I bought an Extralite cassette lockring. It didn't have enough thread length to even start tightening on a Sram cassette. Total waste of €48 euros that was.
    Saying that, my Extralite front hub was fine without any issues. The Extralite HyperRear hub has a cautionary note on its product page about the freehub mechanism:
    "It took more than a year of continuous testing to develop and fine tune the HyperRear full-alloy front-engagement freewheel mechanism.
    This new device is able to manage extremely high torque values, it offers 36 quick engagement positions for a precise feel and a minimal friction resistance.
    Oversized front engagement freewheel offers a much wider teeth engagement surface to spread the transmission torque on, handles over half-ton of chain pull.
    It is a racing assembly sensibly stronger and lighter than our conventional pawls systems, as counterpart coasting is more noisy.
    Mileage of freewheel parts is also lower than conventional pawls systems however wearable parts can be easily replaced."
    Extralite
    I'd be inclined to buy some spare freehub bodies at the same time as the Extralite wheels if you go that route. I only bought a front Extralite hub as I was using my Powertap hub for the rear wheel.
    When it comes to the rims themselves I don't know. With newish products you could either wait for more rider feedback to see how solid they are or buy the rims from somewhere that you know is reputable. A store who will definitely look after you if there are any warranty problems.
    Quote Originally Posted by skiwi View Post
    Back on planet earth, I'm keen to try out the Crossmax 29 SLR. At 1620 with an alloy rim, that looks to be a good bet for an all-round wheel. I've got Mavic wheels on family bikes, but would happily own another set.
    Unless you're sponsored by Mavic or refuse to use carbon rims (both valid reasons) they don't seem to offer much. Their main selling point hopefully being rim durability I guess. The 2013 Mavic Crossmax 29 SLR wheels are £784.99 GBP ($1268 USD / €959 euros).
    Chain Reaction Cycles - 2013 Mavic Crossmax 29 SLR Wheelset
    That's not cheap for what's a relatively heavy 1620g wheelset with proprietary spokes and a 19mm inside rim width. Crossmax SLR wheels were highend in 2008 but they haven't kept pace with technological change since then. The increased availability of stiff, wide, affordable and (mostly) reliable carbon fibre rims in 2013 makes them a much harder sell. You could have a set of Roval Control carbon 29 wheels 1580g and a 22mm inside rim width for about the same price.
    Specialized Bicycle Components
    2013 Specialized Wheels & Tires – Aero & Disc Road, Budget Carbon 29er MTB & More! - Bike Rumor
    An example of what they're competing against for all round everyday training wheels if you're on a budget would be these light-bicycle.com all mountain wheels 1500g, 23mm inside rim width for £400 GBP ($646 USD / €488 euros) including shipping, which are available in a reinforced rim version. Used with a wide tyre a wider inside rim width gives a better tyre profile for improved grip and handling.
    all mountain 29er carbon mtb wheels clincher tubeless wheel ready - light-bicycle
    For race wheels the 1620g Crossmax SLR wheelset would be giving away 170g in weight to the stock 1450g Roval Control SL 29 wheelset on your S-Works Epic, and 460g to something like the 1160g Extralite CarboCamber wheels.
  3. #78
    Nov 2012
    Quote Originally Posted by MarcoL View Post
    it seems they are high, but not very sure if this is enough, have to field test, maybe tomorrow
    Attachment 748007Attachment 748008Attachment 748009
    How did the test drive go with the x-monoring without the chain guide?
    Maybe you can post you're experiences in this thread: forums.mtbr.com/singlespeed/carbon-ti-spiderless-chainrings-833871.html
    (i'm not allowed to post direct links or PM)
    RIDE...
    Reputation: MarcoL's Avatar
    I Will, they worked ok, but as predicted by wr304, the chain guide is needed if you ride aggressively...I am waiting for a chain guide and also for spider from Mathias
    Enviado desde mi iPhone con Tapatalk
  5. #80
    Nov 2012
    Thx for the replay. I'm in doubt to bay te monoring or a xx1 crank. With a added chain guide the cost and weight are about the same and makes the choice difficult. The monorings have a bigger appeal to me.
  6. #81
    RIDE...
    Quote Originally Posted by Crankiness View Post
    Fortunately, there are options on the chain guide, there is one chain guide in Italy that is about 10 grams, and the other one in germany is 36 grams
    ShiftUp Kettenführung Direct Mount Carbon 36g, 97,50 €
    If i got the one in Italy, will be very low in weight; the other option is the spider from EP + sram chainbolts + sram chainring.
    will let ypu know which one works best!
    Saludos!
  7. #82
    Feb 2013
    Awesome
  8. #83
    RIDE...
    EP spider is 20.8 grams!!!!
  9. #84
    Mar 2013
    Another data point on the weight for anybody who's interested. My XL SW Epic SRAM came at exactly 9.99 kg (21.97 lbs) completely stock (incl tubes) with no pedals.
  10. #85
    I wanted to report that I am using the carbocamber wheelset for several months now, I used it during various races and trust me here races are very very tough on the equipment, the cross country usually means a lot of tough downhills on huge rocks, the rims are holding very well so far
