Results 1 to 8 of 8
    aka...appBLING72
    Reputation: aappling72's Avatar
    2013 S-Works Enduro frame seatpost insert depth?
    I have the 2013 Sworks Enduro frameset ordered. Im not fond of the command post due to lack of inifnite adjustability. Looking at the KS Lev and I would like to use the 150mm drop but not sure how far you can insert a seatpost on the new medium frame. May have to stick with 125mm drop.
    Anyone have that info handy?
    What size frame?
    Broken but on the mend
    Reputation: mzorich's Avatar
    Mar 2011
    your going to regret getting the ks lev. problem after problem with that post. the blacklite is awesome and has very little issues
    aka...appBLING72
    Quote Originally Posted by Djg24 View Post
    What size frame?
    Size medium
    aka...appBLING72
    Quote Originally Posted by mzorich View Post
    Ive read nothing but good things about it. Where are you seeing the reports on issues. I have a reverb now, but read that the hydraulic hose won't fit through the new internal routing. That's the main reason for switching. Thanks for any links you have showing this.
    Reputation: Intenseman's Avatar
    Quote Originally Posted by aappling72 View Post
    Are you sure ?
    Fort the "Stealth" version ok...there is a problem with normal hose routing...but not with the other version
    Edit : Custom version with the "Stealth"....hydraulique hose routing with downtube
    'Tentense...or Intenseman
    Stealth Version
    Classic Version
    aka...appBLING72
    Quote Originally Posted by Intenseman View Post
    Stealth Version
    Classic Version
    Where does the hose come out at. I wonder if he had to have a hole drilled somewhere. I actually like the idea of trying the Lev out with it being mechanical and not hydraulic. Just a little simpler for cable change etc... But, I'll look into the Stealth reverb option.
