Page 3 of 4 FirstFirst 1234 LastLast
Results 201 to 300 of 387
  1. #201
    Oct 2012
    Thanks for the info. Would you mind measure the the distance between the screw hole and the end of the protector piece?
    Do you have another link to S-Works graphic?
    Cheers
    Nawa
  2. #202
    Reputation: Intenseman's Avatar
    Google isn't your friend ?
    'Tentense...or Intenseman
  3. #203
    Oct 2012
    Intenseman,
    OK found it!
    I've got to drill a hole on the guard, to minimized the mistake on drilling could you please share the distance between the edge of the guard and the hole?
    Cheers
    Nawa
  4. #204
    Go faster!
    Reputation: tkrowe's Avatar
    Thanks. Looks good.
  5. #205
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    Im glad you guys shared/talked about that cf guard! I ordered one for my stumpy.
    14 Aurum, 16 Fuse, 17 T130
  6. #206
    Quote Originally Posted by TANK01 View Post
    Intenseman,
    OK found it!
    Cheers
    Nawa
    En français dans le texte :
    Heuu , je pense que t'ai donné assez d'infos comme ça
    et de toute manière tous les sabots carbone ne sont pas à 100% identique...à toi donc de mesurer par toi même.
    Un peu d'initiative ne te fera pas de mal ,faut juste enlever les moufles et te sortir les doigts du c...
    P.S : Bon courage pour la traduction
  7. #207
    Oct 2012
    ขอบใจมากสำหรับคำตอบ
    Quote Originally Posted by Intenseman View Post
  8. #208
    Did that CF Gaurd come with the S Works graphic, or was that something you added? The website doesn't show it, but it looks super pro.
  9. #209
    Oct 2012
    The guard didn't come with the decor. Go to page 8, Intenseman was kind enough to share some instruction. You will have to drill the guard to fit it on the frame though.
  10. #210
    Mar 2013
    Quote Originally Posted by ids View Post
    Yeah, Unless you want to void your warranty, the stealth isn't an option. However Jagwire makes a hydro cable of a smaller diameter so if you switch that out for the regular reverb cable it fits perfectly. That's what I had to do.
    Very exciting!
    Can you tell me where I can find this hose, only 5mm on jagwire.com and the internal cabele routing allow 4,5mm
    My first post
  11. #211
    Mar 2013
    Hi everyone I hope this is the correct section for my question... anyone knows the weight of the frames: s-works and the alloy frame(enduro comp)2013?
  12. #212
    Up...
    Still no one???
    Quote Originally Posted by cubebiker View Post
    how many spacer did you guys need to install the xx1 crankset into the pf30 bb?
    I have three manuals and all say different things...
    And btw my frame came stock with a decent play in the front shock mount...
    Anybody else?
  13. #213
    My Build: (26.6 lbs)
    Frame - 2013 Large S-Works Enduro (Cyan)
    Fork – 2013 FOX 34 Talas 160mm
    Bars - 2013 Easton Havoc Carbon (750mm)
    Stem - 2013 Easton Haven (55mm)
    Wheels - 2013 Easton Haven Carbon
    Cranks – SRAM XX1 (BB30)
    Chain – SRAM XX1
    Cassette – SRAM XX 11-36 (10 spd)
    Seat Post - 2013 KS LEV 150mm
    Brakes – Shimano XTR Race w/Fin Pads
    Rotors – Shimano ICE (F-180 R-160)
    RD – Shimano XTR Shadow Plus (mid cage)
    Shifter – Shimano XTR I-spec
    Tires – Bontrager XR4 TLR (F-2.35 R-2.2)
    Pedals – Crankbrothers Candy 3
    Grips – Renthal Lock-on (med compound)
    Saddle – Specialized Henge Pro (carbon rail)
    2013 S-Works Enduro Build Thread-1.jpg2013 S-Works Enduro Build Thread-2.jpg2013 S-Works Enduro Build Thread-3.jpg2013 S-Works Enduro Build Thread-4.jpg2013 S-Works Enduro Build Thread-5.jpg
  14. #214
    aka...appBLING72
    Reputation: aappling72's Avatar
    Nice ride man!!! Be careful te carbon rail saddle. My failed immediately on a g-out and put a nice rip in my jacket and pretty serious cut on my chest. Could har been worse had it not been winter with a couple layers. Otherwise, that is a badass ride. Digging the blue!!
  15. #215
    Reputation: tsefreeflow's Avatar
    Someone on here I thought had a problem with their drive side crank coming loose but cannot seem to track that thread down. Mine is doing the same thing. Can someone help me out and explain... SCRATCH THAT, I see it is just a 10mm hex. SOrry to bother lol
    Tie two birds together and though they have four wings, they cannot fly!
  16. #216
    ids
    ids is offline
    Quote Originally Posted by JimEG View Post
    Good question. I dont think it is possible without drilling the frame though. Would like to here if anyone else knows.
    Has anyone else tried a standard Reverb and then tried the internal routing where the Command Post cable went? I couldn't get the Reverb hose through the exit hole at the top. Too tight. Considering drilling it out a little bit. Had to tape the hose to the top tube. Not so clean of an install. Going to call Specialized first. Not a fan of the Command Post.
    Attachment 774732
    as an FYI, it's doable. I've seen pics of a guy with a reverb stealth on his 2013, he has no issues with it thus far. He was able to route it out the bottom of the TT/ST junction then just the regular internal routing from there. I'll try to link pics in another post. Thought you all would want to know.
  17. #217
    ids
    ids is offline
    hope this works
    http://www.dh-rangers.com/gallery/da...51216064_n.jpg
    All he did was widen the hole into the TT for the cable. I'm going to buy a stealth, and get a hydro kit from Jagwire, then try to get a 90˚ bend piece from goodridge, or someone in hydraulics and fit it to mine as well. Looks super clean.
    -Isaac
  18. #218
    Looking forward to the pics. Thanks.
  19. #219
    Technically its not a S-Works, but here is a few pics of my Enduro Expert Carbon...
    I went full XX1 on the drivetrain. I've upgraded the wheelset to the Roval Carbon Traverse Sl's, changed out the shock for the CC DBAir, and also added the KS Lev post. I have several more upgrades planned.
  20. #220
    Oh yeah, with pedals as pictured, it weighs in at 26.5lbs.
  21. #221
    Go faster!
    Finally got around to taking some photos.
  22. #222
    g_k
    g_k is offline
    -Isaac
    And while looking for a way to route, that'S what came out of his shiny S-Works frame:
    2013 S-Works Enduro Build Thread-p1100975-specialized-enduro-s-works-muell-w1200.jpg
  23. #223
    WHAT?
    Looking for some detailed photos of the Stealth installation.
  24. #224
    What is that????? We're did it come from????
    Quote Originally Posted by g_k View Post
  25. #225
    Quote Originally Posted by ski1970 View Post
    This is from production and can be found in every carbon frame because it is very hard to get rid of this prod waste.
    But I'd like to come back to my question:
    S-Works combined with XX1, how many spacers do you guys have with your crank drive side?
  26. #226
    Feb 2006
    Hi all, just wanting to get an idea of what settings everyone is using for their DB Air. I'm about 85kg (187lbs) with gear, and running 120psi for 30% sag (19mm). Just running the Cane Creek base tune at the moment, but will be looking to tune it a bit more in the bike park next week.
    Initial impressions are the base tune needs perhaps a little less low speed rebound, and a little less low speed compression. Will report back with a bit more riding.
    Cheers,
    G.
  27. #227
    aka...appBLING72
    How many Spacer did you guys need to install the XX1 Crankset into the PF30 BB?
    Anybody else?
    Not by the bike, but I believe it's the one thick spacer on the drive side. I'll do me check when I get home.
  28. #228
    Quote Originally Posted by funkateer44 View Post
    Cheers,
    G.
    I weigh 205 geared up and run 140psi to get 19mm sag. From the base tune I'm running an extra 1/4 turn on hsc and 1 less click on lsr. So far so good. Only had it for a week and its very different from the nomad I'm coming from (in a good way)
  29. #229
    I have only had my bike built up for a couple of weeks now. I am used to riding more xcish machines. I added another click or two to the LSC setting and backed off on the rebound a click. I am running 165psi to achieve the 19mm of sag.
  30. #230
    I still experience heavy bob when pedaling even when HSR and HSC are fully closed... Might be because of the 28t chainring??? Sag is properly set...
  31. #231
    Hsr and hsc have nothing to do with pedal bob. Pedal bob is a low speed event, so Lsc will effect it the most. Put it back to the recommended settings and flip the lever to add 4 clicks lsc. I have almost no pedal bob at all on mine with a 32t chainring and rarely use the lever because of it.
  32. #232
    Oct 2012
    Do you guys have your front sag set too? Here is a good article from bikeradar for setting sag on any bike. I get no bob when my sag is set properly, make sure you have your shocks/forks in open setting when you set your sag.
    Workshop: Setting Up Mountain Bike Suspension - BikeRadar
  33. #233
    Quote Originally Posted by mtnbiker831 View Post
    Sorry I mixed that up. I was actually talking about LSC and LSR...
  34. #234
    What do you weigh and what psi are you running? What kind of bike are you coming from?
  35. #235
    220lbs and running around 160 PSI. Have exactly 19mm Sag with this. I am coming from an Intense Tracer and Yeti SB 66.
  36. #236
    Weird. And you are counting clicks from full open? (Counterclockwise is open) do they stop of keep spinning?
  37. #237
    Yes I am counting from fully open. Never tried if the knobs would stop spinning. Would it make any difference?
  38. #238
    When you purchase the BB you will get a few spacers, non of which are necessary. When you buy the crank it will come with 1 large spacer, run that on the drive side and you're off to the races. This is not counting the SRAM branded seal dust caps that go on each side of the BB bearings.
  39. #239
    Quote Originally Posted by james_95 View Post
    Thank you, that is how I did it. Strange that my non drive side thing that you turn towards the frame just does not touch the frame...
  40. #240
    Does any one know what is is when I compress my rear suspension there seem to be a sticking point and then compresses more? I guess maybe like a bump or a friction point. It does not stop the compression but I defiantly feel something. I have never even ridden the bike yet. Does the shock just need to break in? Any advise would be great. Thanks
  41. #241
    Jan 2011
    Nothing to worry about
    Just the posative and negative air equalising
  42. #242
    Reputation: NoShirt's Avatar
    or it might be the clutch style deraileur. Roll the cage forward so there is no tension on the chain and cycle the suspension. I had the same thing going on and it made me nuts thinking it was the bike, but it was just a slight clunk in the movement of the rear der.
    Have a nice ride!
  43. #243
    Jun 2010
    It's the XX1 RD. Both my SJ Evo with XX1 and my buddies Enduro S-works have the same noise feel. It seems like it is a common issue with the SRAM type 2 RD.
  44. #244
    Do not think it is the rear mech or any drive train issue.
    I am not even sitting on the bike when it does this or rollong the bike. It happens just by pushing doen on top the seat or bouncing my upper body weight on the bike. Rear Mech does not even move...
    Quote Originally Posted by Mr. Lynch View Post
  45. #245
    there is no noise what so ever. Just a sticktion feel not huge but just on the 1st maybe 10mm of the push then it goes on to more travel as normal. I am standing and pushing down with my upper body on the seat.
  46. #246
    Jun 2010
    try pushing the arm on the RD forward. There is some tension before the clutch releases. When the suspension starts to move there is a slight amount of chain growth and it has an almost sticky feeling until the clutch releases. I notice it in the garage or on the street, but you dont feel it on the trail very often if at all.
    Your pivots could also need the be greased or the shock just needs to be broke in and the seals are a little dry.
  47. #247
    Still has the sticktion
    I help the rear cage all the way FWD so the chain was just hanging basicly, it still did it.
  48. #248
    It's the negative air spring. Don't worry about it, you'll never notice while riding since you'll sag the shock past that part of the travel.
  49. #249
    Ride Hard. Go Fast.
    Reputation: OldschoolBMXer's Avatar
    New S-works owner here. Bike is not quite dialed yet but getting there. I was curious if anyone knows about a shock shuttle that is available for purchase to drop the BB down a bit. Thanks in advance.
  50. #250
    the refurbished one
    Reputation: hball's Avatar
    blue beats them all!
    nice ride!
    Sokrates is dead, Galilei is dead, Newton is dead, Einstein is dead, Pantani is dead and i am feeling sick too.
  51. #251
    Is anyone having problems with the dropper post cable rubbing on the DB Air Can? Mine is routed as short as possible, but it still rubs when the seat is lowered. I've covered it with a frame protector, but would like to avoid it in the future.
  52. #252
    Ride Hard. Go Fast.
    yah, nothing you can do about that other than what you're doing. If KS LEV ever comes out with a setback remote post, I'd be the first to purchase it. That's the only reason why I hang onto the command post, the cable design is horrible.
  53. #253
    Reputation: AaronJobe's Avatar
    Whate did you guys end up paying for your 2013 s works frames? Please PM me if you dont want others knowing. Thanks
  54. #254
    Retail is $3500, and I don't regret a single penny spent.
  55. #255
    Have any of you been on an sb66c? If so how would you compare the two?
  56. #256
    Feb 2006
    Hi AaronJobe,
    I tested an SB66c for a weekend before I eventually chose the S-Works Enduro. One way I would sum up the differences between the two is that I would view the SB as being an XC'ers long travel bike, and the Enduro as being a DH'ers short travel bike. But in all honesty, this comment is more aimed at the SB arguably not being as gravity capable, because I find the Enduro to climb as good as the SB I tested (though different climbing characteristics).
    Please note that I am still in 'shakedown' for my Enduro, and working out my ideal suspension settings. I would say that pedaling is good on both frames, however; the SB I felt was firmer (almost hard-tail like) while climbing, though tended to get hooked-up on roots/rocks. The Enduro still climbs very well, doesn't get hooked up the same, and affords a bit more traction.
    The Enduro is my pick for DH ability. Plusher/more progressive, with much more tunability with the CCDB Air. I preferred the geo. for DH more on the Enduro too. I had issues blowing through all travel with the SB on small jumps/drops, with correct sag set, though I understand that a custom Fox tune on the CTD can help.
    Biggest reason I went with the Enduro over the SB is the geometry. The top tube length on the SB is extremely long. I tested a Medium SB which had the same length as most manufacturers similar Large frames. I felt the Medium SB was far too long for me (I'm around 5'9" tall), and I suffered on descents accordingly. I wasn't comfortable with the idea of riding a Small SB, though didn't get a chance to test one. For me, the geometry of the Enduro is much more conventional (though the front end was lower than what I was used to previously, I soon adapted and now love it), and feels really dialled for me.
    Hope that helps. Let me know if you have any specific questions and I'll try to answer them.
    Cheers,
    G.
  57. #257
    Other frame protection : Rockguardz
    http://img845.imageshack.us/img845/7711/0001qok.jpg
  58. #258
    May 2010
    @aappling72 -- what size Mojo HD were you riding? I'm looking at picking up a S-Works Enduro and while the geometry numbers on the Specialized site look similar between the large frame Mojo HD and the large frame Enduro, I'd like an opinion from someone who has ridden both. The LBS in the area does not have an Enduro for me to check out and they have suggested a medium (I'm 5'10"). My current large Mojo HD has a 50mm stem and is perfect.
  59. #259
    Oct 2012
    Intenseman
    Which pedal cage do you run with your S-Tarack, al or plastic? How do you like it?
  60. #260
    I had the same noise coming from my 2013 S-Works Enduro, I deflated the DB Air and compressed the suspension to find the source of the clicking, it was the XX1 Derailleur. I called SRAM and they confirmed that it was an issue they have come across and it is caused by the chain being cut too short at install which results in too much tension on the Derailleur.
    To measure the correct length, I was told to run the chain outside of the Derailleur over the largest rear chainring, mark that link then add one more link and cut the chain there. Problem solved? I don't know yet...I will post my comments after I have tried this!
  61. #261
    I would love to see how this was done, can you post pics and get details on how he fed the cable through?
  62. #262
    5'10.5 with a 31.5" inseam what size frame? Longer arms and torso
  63. #263
    Cyan Frame ORDERED!!!!!! STOKED
  64. #264
    Cyan frame Bought!!!!equally stoked.
    Just need to pick it up...
    Question, what headset is supplied with the frame?
    I will likely go with a 1-1/8 steer tube(non-taper) and need to know what lower race to buy to get it to work. Cheers.
  65. #265
    So I got a call back and the Cyan is sold out I guess I will wait and see colors for 2014
  66. #266
    If anybody knows a shop that has a 2013 Cyan Medium Enduro Please let me know
  67. #267
  68. #268
    Intenseman
    Plastic
    Fine...only 3 rides
  69. #269
    Quote Originally Posted by samdemo View Post
    Wow, no one knows what headset comes with their frame?
    Best I can figure its an FSA, but a conformation would be nice. I've yet to receive my frame and I'd like to order a 1.5 to 1-1/8 headset reducer before it arrives.
  70. #270
    Quote Originally Posted by AaronFPeet View Post
    my wife bought the Enduro carbon expert and it looks like the cable rubs on the Fox shock too when the seat is in the low position. I was thinking I would just install one of these made by Jagwire to prevent the cable from dropping down. The wife and I are both gonna get KS Lev posts, so now it wont be an issue
    I figured I'd try mounting one of these on the frame just above the shock.
  71. #271
    Reputation: EnduroBob's Avatar
    Mar 2013
    Quote Originally Posted by AaronJobe View Post
    Are all the 2013 Sworks frames sold out already? Red still available?
  72. #272
    Quote Originally Posted by EnduroBob View Post
    There is a red medium available on their dealer trade site in denver but all frames are gone no more batches until the 2014
  73. #273
    Mar 2013
    So does that mean it needs to be ordered from a LBS in CO? Slim pickings! Looking for a medium though.
  74. #274
    Oct 2012
    The frame comes with FSA headset so there is no need to order another headset.
  75. #275
    No, they will ship it to your dealer
  76. #276
    I have been stoked on my s works enduro except for the fork...I have a 2011 fox 36 rlc kashima on it that i bought(nos), and coming from a lyrik on my last bike it sucks. Lots of brake dive, poor mid support, and will not come within an inch of full travel on any hit. I like the looks of the new pike but the 15mm axle concerns me as I am about 205 geared. So...are my concerns warranted? Is 15 mm going to make a difference? I am also considering getting my fox pushed but I think I may be throwing money at a turd. Opinions?
  77. #277
    Thanks.
    I'm not looking to buy a new headset, just thinking of running a straight steer tube not a taper. To do so, I would need to buy a different crown race.
  78. #278
    Hi Fellas, I finally found the cash to buy this thing and the bloody bike is sold out everywhere in Australia!!! Is it the same in USA, Europe, etc?? That is crazy!!!!!
    So desperate to get it and can't even it find it as a frame set.
    Is Specialized doing this on purpose or what?
  79. #279
    Knob scrubber
    Reputation: Finksta's Avatar
    Jan 2013
    Quote Originally Posted by iguanabartola View Post
    I found 5 stores advertising them here, Specialized Mountain - Dual Suspension Bikes for Sale in Australia
    Don't know if that means they actually have them, but worth a try?
  80. #280
    I am about 1 in taller and 1/2 in longer inseam and large with a 50mm stem fits perfect.
  81. #281
    I have already contacted all those waaaaay back. The bikes are sold out. The just haven't removed the adds. I went through the trouble of contacting every single Spesh dealer here. Nothing. NIL. NADA.
    Just got a call from LBS offering me the 29er but don't want to buy before I try. I know the rave is huges but still, a lot of money to blow on a bike I haven't tried being such a bigh wheel.
    Quote Originally Posted by Finksta View Post
  82. #282
    Knob scrubber
    Jan 2013
    Re: 2013 S-Works Enduro Build Thread
    Yeah I thought that was probably the case. My lbs says they'll have the enduro 29 in store next week, I'm pretty keen to have a look at one of these bad boys myself.
    Sent from my GT-I9100 using Tapatalk 2
  83. #283
    Knob scrubber
    Jan 2013
    Don't know if you would consider a used one, or what size you are after, but found this one on Rotorburn http://http://www.rotorburn.com/foru...00#post2660100
  84. #284
    Have any of you considered buying an Enduro Expert Carbon bike in the Cyan color? The frame is the exact same carbon that's used in the S-works version. I know it doesn't come with the CC DBAir shock and all, but you could buy one aftermarket if you really wanted. Just a thought since the S-works Enduros seem to be sold out for the year.
  85. #285
    Reputation: Znarf's Avatar
    Aren´t the Expert frames Fact 10 and the Sworks Fact-11?
    Don´t know if there´s any real difference though.
  86. #286
    Both the S-works and Expert Carbon frames use the Fact 11m carbon this year.
  87. #287
    May 2005
    The frames should be the same. They are the same on the 29" Enduros as well.
  88. #288
    Thanks Finksta. Been talking to the seller for a bit already. Thinking about it and hopefully inspecting the bike next week.
    Gotta say that still prefer new and have the warranty on the frame.
  89. #289
    What colors will be available for the s works frame for 2014
  90. #290
    Mar 2011
    Mojo Wheels in Colorado has a complete red medium. Just to put it out there for anyone looking.
  91. #291
    Jun 2010
    There are still full bikes available from Specialized, but framesets are sold out for the year.
    I picked up a medium S-works Enduro yesterday, but i'm selling the frame. My 2013 SJ was stolen and it was basically built identical to the s-works Enduro, so it was easiest to buy the Enduro and do a frame swap.
  92. #292
    Reputation: adhyanz's Avatar
    May 2010
    very nice frame form spez, its a dream to have one...hiikss
  93. #293
    May 2010
    Quote Originally Posted by Ordinarybikes View Post
    CCDB air vs FOX Float CTD Performance shock with proprietary AUTOSAG
  94. #294
    May 2010
    still working
  95. #295
    aka...appBLING72
    What? Already? Hopefully it's to get the 29" version. This bike is amazing.
  96. #296
    Would u trade yours for a 29"?
  97. #297
    Apr 2013
    Mr lych do you still have the frame for sale?
  98. #298
    Apr 2013
    What size is your bike and is it still for sale?
    thanks
  99. #299
    Hi guys!!! Do still satisfy with your xx1 groupset???
    I have installed one GXP in my Enduro S-works 2010, with 32T chainring. Everything ok, but in steep climb when i need to use the 3 lowest gears I fell that the chain makes to much retention which implicate more strengh in the cranks. I stated that the cross chain in the 42 drive is much more than in the 10 drive. If increase the chain lenght when i'm on 10 drive, the chain get too large. I have already try to put the chainring closer to the frame but it isn't possible. I used to have 3 chainring and when i need the 22T with 32 drive everything is more fluid without strengh. I disapointed because I get earlier tired. Someone notice the same problem????
  100. #300
    So, I'm building my Enduro up and it feels like the rear end is clunking....track it down to the forward end of the CCDB Air. The mounting bolt is tight yet it feels like the bushing is gone....WTF?
