Page 2 of 4 FirstFirst 1234 LastLast
Results 101 to 200 of 387
  1. #101
    Jun 2010
    How does it climb ? long steep climbs....is it slow?
  2. #102
    WHAT SIZE do I need. I am 5'9". I think a medium but when I went to the geometry chart I saw they shrunk the top tube from the 2010 and 2011 tope tube on the enduro for the 2013. I had the 2011
    sworks enduro and it was a perfect fit with a 60mm stem..... I am scared to get a medium because it is 20mm shorter on the top actual top tube measurement. What is the better length to look at the actual or the horizontal length? Should I get a large or the medium?? Please let me know your thoughts.... I am stressing out over this
  3. #103
    aka...appBLING72
    Reputation: aappling72's Avatar
    Quote Originally Posted by ski1970 View Post
    I'm 5'11" and the medium for me with 60mm stem is perfect for XCish and 50mm for more aggressive AM type. I guess it all depends on your torso/reach etc... I have always ride medium when I was on the border just for the quicker handling and agility.
  4. #104
    Rocket Ron /Racing Ralph on an Enduro? These are pure CC tires!
  5. #105
    aka...appBLING72
    Quote Originally Posted by SouthernVelo View Post
    I can't speak for aappling, but I had good luck pulling the front shock pivot bolt. After pulling the bolt you can lower the front end of the shock just enough to stick your pinkie finger in the cable exit hole. Feed the housing until it hits your finger then use your finger to guide the housing out of the frame. Takes about 5 minutes.
    Like SV said it was pretty simple. I used a different approach. I just used an L shape Allen key(3mm) and before pushing housing through put it above the exit hole. Hen the housing protruded I simply pulled down on the Allen key and that was it. Another friend I spoke to made a loop with an old spoke and ran the housing into that and pulled it down. So there are a few ways to go about it. All in all very simple.
  6. #106
    I too have alway been on a medium however I was looking at a ibis mojo and it seemed to short and cramped and I had a carbon Nomad and it was almost to short, ( there is no way I could have ran a 60 or 50 stem on it and that is what I like) My torso is paportinate to my lower legs of a 30 31 inseam.
  7. #107
    aka...appBLING72
    Quote Originally Posted by dirkinho View Post
    That's what they are listed as, but I have ridden them hard in some of North Georgia's most demanding terrain at speed through some serious babyhead rock gardens, rocky creek crossings, and pushing hard through corners. The new Rocket Rons tread is actually quite aggressive and has great traction. The Racing Ralph has a nice predictable drift/breakaway that makes for nice cornering but pretty decent traction until it gets a little wet. Then it can be underwhelmed. At 28-30psi rear under hard cornering no squirmy feeling. I have a nobby nic 2.4 w/Trailstar as well and honestly it does have better front traction and damping properties, but for the terrain around here, unless im doing a Super D, or heading to Pisgah, this combo with the lower rolling resistance is working great. I have the butcher as well and fast trak combo that I like too, but you can feel the extra weight of the butcher on long rides and the new Rocket Rons cornering is quite impressive.
    Nothing beats real world testing, so just because it's listed as XC, doesn't necessarily mean it can't blur the lines of aggressive XC/AM riding. The life may be shorter lived with how I ride it, but the combo is treating me right.
  8. #108
    got your point. I have been riding Rocket Rons for 3 years now in CC races. Great under dry conditions but there are better alternatives in mud/rain at least as front tire.
  9. #109
    HAHAHAHAHA!!!!!!!!!!! yea...have to agree....I used the NN 2.4 SS on frt and 2.2 RR SS on rear of my stumpy evo and they were HORRIBLE
    IMO...even in the SS the sidewall is still too thin
  10. #110
    Reputation: trailwerks's Avatar
    Quote Originally Posted by Intenseman View Post
    Here...in France
    Leoseven
    He will make the mold this week
    Soon available on his website
    P.S : i have same protection on my Intense M9
    These are very cool. I followed the link to the site and as someone said tough to navigate for non French speaking folk as myself.
    Has anyone had experience getting these in the US? Any other items like this?
    Cheer,
    Curtis
  11. #111
    aka...appBLING72
    What do you run for trail in the wet? Do you have a spare set of wheels that keep a different tire setup handy?
  12. #112
    Jun 2010
    How does the enduro s works 2013 climb? Is it slow going up steep long hills? Does the cane creek shock without a lockout option affect the climbing? Please i am about to buy a new bike and i am between the enduro or the new stumpy evo
  13. #113
    ... and if we just ...
    if u that worried about climbing...then get the stumpy EVO
  14. #114
    aka...appBLING72
    Quote Originally Posted by EGREGOR View Post
    Really is all about the majority of riding you do. My enduro is 26.3 lbs and climbs better than my Mojo HD that was 28.7lb DW link. Granted thats 2.5lbs weight loss, but the actual traction and efficienct increased also. I was able to climb this one techy section 3 for 3 times, where in the past i was 1 for 5. Real workd proof...for me at least. That's both bikes at 28% sag no platform on either. Although the DB Air has a 4 click add of LSC adjustment it knocks the edge off just enough to provide a nice feel when pressing hard up hill. If you want more pedal efficiency run 25-26% sag, but then you are starting to firm up a bike that was intended to go go down fast and you slightly compromise that aspect of its performance. You won't go wrong with either the stumpy or enduro. One will be lighter than the other and blue the lines between descending confidence and climbing efficiency.
  15. #115
    Jun 2010
    Thanks a lot! ...i am leaning towards the enduro ...I have a GF Superfly 100 but will like a more AM bike with more travel , i was going to get the santa cruz tallboy LTc until i saw the new specialized bikes! and the Enduro is a beauty. But it will be going back to a 26 from a 29
  16. #116
    Reputation: Intenseman's Avatar
    Quote Originally Posted by trailwerks View Post
    Cheer,
    Curtis
    Hi Curtis
    For Info, 2013 Carbon Enduro model will be available very soon (8-10 days), I sent him an S-Works Molt
    https://fbcdn-sphotos-f-a.akamaihd.n...42684738_n.jpg
    https://fbcdn-sphotos-f-a.akamaihd.n...25996893_n.jpg
    https://fbcdn-sphotos-g-a.akamaihd.n...71308801_n.jpg
    'Tentense...or Intenseman
  17. #117
    aka...appBLING72
    Hi Curtis
    Nice! Keep us posted when they are ready!
  18. #118
    I have already received my wheelset
  19. #119
    Go faster!
    Reputation: tkrowe's Avatar
    Hi Curtis
    Thanks for getting the ball rolling. I'm interested in picking up a set once they become available.
  20. #120
    aka...appBLING72
    Wheels look nice!! Is the last one your XD driver body? For what hub/spoke combo. Weight
  21. #121
    Aivee Hubs (French products) / Sapim CX Ray
    AiveeAccueil
  22. #122
  23. #123
    aka...appBLING72
    Looks NICE!!!
  24. #124
    Go faster!
    Awesome ride. You're already upgrading and I haven't even finished my build.
  25. #125
    aka...appBLING72
    Have any of you guys had any issues setting up the XX1 derailleur? Mine is working and shifting fine, but it feels like I'm getting a sound in the middle gears like it is wanting shift up or down. I can remove it a little with the barrel adjust, but then there is a slight compromise in one direction or the other direction of shift. Almost a slight delay due to the cable tension. I followed the setup instructions to the T. Setting the B tension was a list different than any other detailleur. So I may just start over with that.
    Again, it is working great even with this small little hiccup. Could be a little cable stretch occurring too. Just wanted to see if anyone else had ran into this while riding.
  26. #126
    Nov 2006
    What size headset cups does the Enduro frame take? Looked on the Specialized site but it was vague. Looking to use an angle adjustable headset to slacken it to around 65 degrees. Thanks!
  27. #127
    aka...appBLING72
    Quote Originally Posted by capslayer View Post
    Not sure. However, I may be wrong, but I don't think you can run an Angleset with this frame since it doesn't use cups that would interface with the gimble (ie.Cane Creek-style) that allows you to adjust the head angle. I would check with them and Specialized first to protect your frame.
  28. #128
    AiveeAccueil
    looks awesome!!!! but isnt your rear tire on backwards?
  29. #129
    Reputation: rcjonessnp175's Avatar
    Aug 2010
    How you guys liking the 34 on the front? Contemplating ordering a float 36 for my build but do have a 2013 34 float I could put on her. Just wondering if in very rocky terrain ie Colorado if your feeling the front end isn't up to task to keep up with that rear end? Thanks for input
    Jonesy
  30. #130
    aka...appBLING72
    Quote Originally Posted by rcjonessnp175 View Post
    Jonesy
    I haven't noticed any issues with fore/aft flex. Tracking on rough N. Georgia rootu/rocky terrain has been just as confidence inspiring as my Lyrik/36's I've owned. The lower weight helps too. I'm actually getting an Xfusion Slant to try ad well to see which one feels better damping wise. I'll post some reviews once it comes in mid to late Feb
  31. #131
    Aug 2010
    Good to hear brother sounds like ill use the 34. It's been great on my stumpy evo
  32. #132
    Jun 2010
    Okk
  33. #133
    Is it safe to run a 180 Fox Float on this bike. I know Specialized says you can only go up by 10mm from the amount of rear travel (165mm) but has anybody done it and will the frame handle it? I would only do it when I take the bike to a mountain bike park like Whistler or Trestle and Keystone then go back to the normal 160 fork.
  34. #134
    Just do it ! If anything happens to your frame, nobody will ask for the fork length.
  35. #135
    Any of you S Works owners care to post a photo with better lighting of the upper shock eyelet? There is one early in this thread but the lighting isn't good, can't see the eyelet.
    I would appreciate it.
    OMG.... just gorgeous... man, that is a good looking bike.
  37. #137
    I asked the question as saving for a frame and thinking on using my 180mm TALAS and got told it will defo void warranty plus the bike will be way to slack.
    The bike might handle it though but I think only a handful of people have been able to get their S-Works therefore, no real feedback might be found on the interwebs.
    Quote Originally Posted by san_andreas View Post
    Yeah, do it as Specialized will be so dumb to see the broken frame and not work out the cause of it.
  38. #138
    Oct 2012
    New question here.
    Beautiful bike you have. I'm getting mine built very soon.
    I have problem finding info on the headset compatible with the frame, so I'm curious what headset do you use for your build?
    Thanks so much
    Nawa
  39. #139
    Leoseven 2013 Spe Enduro Carbon....Carbon protection will be available next week
    (2013 Enduro Allow model on photo)
    ENDURO CARBON 2013 - Leoseven
    Eric
  40. #140
    Reputation: tsefreeflow's Avatar
    Eric
    How would one order one if they do not speak French? Do they or would they even ship to the US?
    Tie two birds together and though they have four wings, they cannot fly!
  41. #141
    Knob scrubber
    Reputation: Finksta's Avatar
    Jan 2013
    Re: 2013 S-Works Enduro Build Thread
    I use google chrome which translates the the entire website. I hope they ship outside the eu, I want one and I'm in Oz.
    Sent from my GT-I9100 using Tapatalk 2
  42. #142
    I'm French...
    He can ship outside Europe...but Only in America & Asia
    Eric
    "Règle N°3: Aire géographique
    La vente en ligne des produits et services présentés dans le site est réservée aux acheteurs qui résident en France, dans les Dom-Tom, Monaco, Europe, Amérique, Asie."
    Contact him by mail
    info@leoseven.fr
  43. #143
    What do you think of the blue (Cyan)
    I just picked this up yesterday...2013 S-Works Enduro Build Thread-img_20130202_111039_412_2.jpg2013 S-Works Enduro Build Thread-img_20130202_111032_059_2.jpg2013 S-Works Enduro Build Thread-img_20130202_123908_606.jpg
  44. #144
    Go faster!
    That blue looks killer.
  45. #145
    Hey Intenseman, I have a stock '13 Enduro and it comes with an MRP Chain Guide. I was thinking about taking it off because it seems like the XX1 doesnt need it. Have you had any chain dropping problems?
  46. #146
    Is the steer tube (head tube) on the new S Works enduro regular like a normal bikes bottom of the head tube? Meaning when you take the fork off is it normal like other bikes and forks or is it like past enduros were you need a special type adaptor thing to put on the fork to change forks? I had a 2011 enduro S Works and I had to buy and utilize a certain adaptor on the fork I put on it. Please let me know. Thank you
  47. #147
    Anyone else waiting on a frame that was supposed to ship this week?
  48. #148
    Feb 2006
    Hey there what width BB/cranks are to be used with the S-Works frame? I have my frame ordered and I'm hoping to run Shimano cranks with the Raceface PFBB30 adapter. I presume I'll need the 68/73mm cranks and adapter (i.e NOT the 83mm one). Cheers.
  49. #149
    Reputation: tshred's Avatar
    Dec 2004
    Quote Originally Posted by JimEG View Post
    Yes...
  50. #150
    Quote Originally Posted by james_95 View Post
    I just picked this up yesterday...Click image for larger version.
    What size is that?
  51. #151
    Quote Originally Posted by cubebiker View Post
    What size is that?
    large
  52. #152
    Quote Originally Posted by taylor.roberts View Post
    No problem without MRP Chain guide (I don't use mine)
  53. #153
  54. #154
    ids
    ids is offline
    I am playing the waiting game on many things at the moment as well.
    Thus far I've got most of the build figured out, but had to recently change my plans instead of waiting for Chris King to produce an xx1 driver... Initially I was told it'd be April and I'd have one in my hands, but nope... Anyhow, the build is as follows. still deciding what to do wheel wise...
    Red frame, size Large( wanted blue, but that would have been late March-apparently 1 went into the UT distro, but it was already paid for... Perhaps it's the one in this thread...)
    E160TA currently running, and still love this fork. Passively looking for a Durolux or a Vengeance as I'd like to try them out...
    Sixc crankset, and rf ring
    xx1 shifting
    XTR trail brakes
    Enve Bars
    Thomson stem, looking at one of the new twenty6.
    Reverb dropper
    Wheels are looking like the Flow-ex on 350's. I've had the 240s, and don't have the spare $ to drop on them at the moment... Would have been nice if I could have kept my Chris King on Roval Carbon rims, but couldn't handle the wait...
    Anyone tried throwing 650b's in their frame? I'm going to check clearance today and see if it's a possibility.
    Oh, and my frame weighed 6.46 lb with the shock and seatpost clamp, on my ipad so i don't have the picture of it. Spesh didn't send all the parts I needed initially, as it's a warranty replacement.
    Cheers
    -Isaac
  55. #155
    Size Frame/Tyres
    Intenseman
    What size is your frame?
    How is the Ground Control tyres comparated with Butcher and Purgatory?
  56. #156
    Quote Originally Posted by tshred View Post
    Yes...
    Mine shipped. Supposed to be at LBS tomorrow.
  57. #157
    Quote Originally Posted by goncallf View Post
    Intenseman
    Medium
    i will use butcher/purgatory on mountain terrain
  58. #158
    Has anyone built theirs up with Shimano/Race Face cranks, or anything that requires a PF30 BB adapter to 24mm spindle? How is the chain line coming out?
  59. #159
    What is your weight and shock settings including air pressure?
  60. #160
  61. #161
    I saw Keene's bike with a stealth reverb, it looked like the routing was down the down tube, under the bb then into the frame somehow...anyone know how?
  62. #162
    ids
    ids is offline
    Likely just a hole drilled above the bb, I've seen a few people do this on Alu frames. It voids warranty for all is regular folks, maybe it's an addition on the 2014 frames.
  63. #163
    What are the base settings for the DB Air?
  64. #164
    ids
    ids is offline
    Here's what the "Recommended settings for the Enduro" card say:
    I think it said to start with roughly 75 psi and check sag there.
    recommended sag 19mm
    Compression:
    HSC: 1.25 turns from open
    LSC: 4 clicks from open
    Rebound:
    HSR: 3 turns from open
    LSR: 10 clicks from open.
    Hope that was what you wanted.
    -Isaac
  65. #165
    Quote Originally Posted by ids View Post
    Compression:
    Rebound:
    -Isaac
    Thanks. I just picked mine up today, and it came with a settings card from Cane Creek.
    I am really amazed at how well the S Works package and peripherals are put together. Really impressed. I'll post some photos once I get it built.
  66. #166
    QUESTION: What is the threaded hole right next to the chainstay pivot on the lower seat tube drive side for. I know it is not a ISOG screw hole??
  67. #167
    ids
    ids is offline
    It's for an s3 mount of a chain guide or front derailleur. The e-type xcx guide from e-13 fits perfectly into that system.
  68. #168
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    Did you happen to get the bike at Center Cycle?
    14 Aurum, 16 Fuse, 17 T130
  69. #169
    hi intenseman! i notice in your pics you have carbon bash guard on downtube with "sworks" decal. did you remove the original decal from downtube or did you use new sworks decal for carbon bash guard? thanks!
  70. #170
    hi! what length/rise stem are you all using for a medium frame?
  71. #171
    double post. not sure how to delete this one.
    Attached Thumbnails Attached Thumbnails 2013 S-Works Enduro Build Thread-img_4550.jpg
  72. #172
    Big thanks to Dave at Center Cycle in Renton WA!
    More info here
    Ride: This New Bike - 2013 Specialized S Works Enduro
  73. #173
    Feb 2006
    JimEG, I'm liking your build. I have something similar coming along myself. What's the deal with the 2mm offset bushing (is it a stock part)?
  74. #174
    nice builds guys
  75. #175
    Quote Originally Posted by funkateer44 View Post
    You can get them on eBay. Not a stock part. I got lucky. I had one left over from my HD and it was a perfect fit.
  76. #176
    Jun 2010
    Nice build Jim! I also wanted to thank you for the deal on the stock wheelset. They fit my build real nice!
  77. #177
    You are welcome! I've been buying bikes from Dave and Center Cycle for over 10 years. He always has the good bikes and the service is top notch. Glad that worked out for everybody.
  78. #178
    Go faster!
    Anyone else notice that their rear triangle has started to develop some play?
  79. #179
    Which pivot(s)?
  80. #180
    Go faster!
    Due to the nature of the Specialized warranty and the fact that I've logged only a few rides on my new frame, I took it to my shop for inspection. Their mechanic informed me that the upper shock bushing is worn out and qualifies as a warranty repair. Hopefully the replacement bushing fixes the problem. Let me know if any of you experience the same problem.
  81. #181
    Thanks for following up. That kind of wear is actually common to all suspension bikes and a minor repair. Cool to hear Specialized took care of it.
  82. #182
    Go faster!
    I kinda agree. I guess i was trying tomsay that it is not common for bushings to wear out in 6 rides. Had I been riding my bike regularly for 3 months then it would be expected wear. At least that was the experience I had with my old nomad. Keep an eye on your rig and let us know if you experience the same problem.
  83. #183
    I missed the 6 ride part. That is premature.
    I have actually changed mine to a different 2mm off set bushing to slacken the bike and lower it a little.
    I'll keep an eye on it and follow up if it wears prematurely(not that Specialized would be responsible for this aftermarket one).
  84. #184
    Reputation: NoShirt's Avatar
    <a href="http://www.flickr.com/photos/thebucksadventures/8490195723/" title="Contrast by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8233/8490195723_217afc8da4_z.jpg" width="640" height="427" alt="Contrast"></a>
    <a href="http://www.flickr.com/photos/thebucksadventures/8490196503/" title="carbon hoops by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8096/8490196503_248098ab3c_z.jpg" width="640" height="427" alt="carbon hoops"></a>
    <a href="http://www.flickr.com/photos/thebucksadventures/8491295218/" title="standover by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8378/8491295218_80630045ce_z.jpg" width="427" height="640" alt="standover"></a>
    <a href="http://www.flickr.com/photos/thebucksadventures/8490195545/" title="Garage Days by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8505/8490195545_f4e0d176f9_z.jpg" width="640" height="427" alt="Garage Days"></a>
    <a href="http://www.flickr.com/photos/thebucksadventures/8491293472/" title="1x10 setup by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8526/8491293472_3138784740_z.jpg" width="640" height="427" alt="1x10 setup"></a>
    <a href="http://www.flickr.com/photos/thebucksadventures/8491295886/" title="top tube by The Buck's Adventures, on Flickr"><img src="http://farm9.staticflickr.com/8372/8491295886_3fe75dd192_z.jpg" width="427" height="640" alt="top tube"></a>
    Have a nice ride!
  85. #185
    Feb 2010
    Can you run a stealth reverb on the sworks does anyone know?
  86. #186
    Quote Originally Posted by Trip Fontane View Post
    Good question. I dont think it is possible without drilling the frame though. Would like to here if anyone else knows.
    Has anyone else tried a standard Reverb and then tried the internal routing where the Command Post cable went? I couldn't get the Reverb hose through the exit hole at the top. Too tight. Considering drilling it out a little bit. Had to tape the hose to the top tube. Not so clean of an install. Going to call Specialized first. Not a fan of the Command Post.
  87. #187
    2013 S-Works Enduro Build Thread-img_6569.jpg2013 S-Works Enduro Build Thread-img_6571.jpg2013 S-Works Enduro Build Thread-img_6572.jpg
    Not possible to use Reverb Stealth without drilling the frame (like Curtis Keene S-Works)
    Possible to use Reverb classic (juste file the hose hole 4mm to 5mm)
    http://img228.imageshack.us/img228/97/6277.jpg
    Eric
  88. #188
    Feb 2007
    im sure this is in some thread, does anyone have a "real" frame weight of the 2013 enduro carbon ?...thanks
  89. #189
    ids
    ids is offline
    Yeah, Unless you want to void your warranty, the stealth isn't an option. However Jagwire makes a hydro cable of a smaller diameter so if you switch that out for the regular reverb cable it fits perfectly. That's what I had to do. I'm also debating getting a LEV later on to have 6" of dropper, and a stationary cable.
  90. #190
    ids
    ids is offline
    Quote Originally Posted by burpp View Post
    The s-works weighs 6.46 lb, size large with axle, shock, and chainstay protector. Don't know how much the non-S-works model weighs...
  91. #191
    Executive User - UK
    Nov 2008
    Quote Originally Posted by speedsterR View Post
    the one I saw looked like he ran the hose through the top tube and out the normal dropper post entry/exit point near the headtube.
    Liking them '13 Enduro's BTW :-)
  92. #192
    Titanium offset bushings-
    Burgtec Titanium Offset Shock Hardware | Burgtec
  93. #193
    Reputation: Znarf's Avatar
    Hi,
    I'd like to ask you happy Enduro owners a question, I need your help :-)
    I want to buy an Sworks frame and I have a short torso and long legs.
    I'd need 27,5cm of seat post (measured from top of the seat tube at frame to the saddle rails) showing on a large frame. Is that possible with a Command Post or would I need a 420mm Reverb or something alike.
    If I explained that not good enough, maybe you could tell me, what the minimum insertion for the seat post on a large carbon Enduro frame is (cm, mm or inch is fine)
    I could then determine if I could get away with a large frame with my inseam of 36.6".
    I appreciate any help.
    Thanks a lot,
    Znarf
  94. #194
    Oct 2012
    Quote Originally Posted by Znarf View Post
    Hi,
    Thanks a lot,
    Znarf
    Whats ur height? Specialized quit making the XL frame for the enduro and even dropped the XL for the 26er stumpy.
  95. #195
    Mar 2011
    IntenseMan.....how were you able to get the S-Works decal to replace the letters the LeoSeven protector covered? Did you get it from them like that or do it yourself?
  96. #196
    Hi Stumpynerd,
    I am "only" 6ft,but my legs are really long. My torso is short, my arms are long again though. Like an Orang Utan.
    I currently ride a 2011 Stumpjumper FSR 29er in size XL.
    The 530mm or 21" seat tube is quite good for me, with a 125mm Reverb post about 1inch of post is showing under the Reverbs seat collar.
    The top tube is a little long for me though, I use a 30mm stem.
    For a more aggressive bike I'd like a smaller fit though.
    The Large Enduro and its 617mm TT looks perfect. Just the seat tube is a little on the short side for my physique.
    I guess I'll get away with a 425mm post though. Just don't want to damage the precious carbon frame...
    Greetings Znarf
  97. #197
    Oct 2012
    Intenseman
    I ordered the same guard from Leoseven but it came with no instruction. Would you be kind enough to share how to fit one on the frame? And the sticker you got.
  98. #198
    Go faster!
    Intenseman-
    Can you post a few pics with the new cf protector installed?
  99. #199
    How many Spacer did you guys need to install the XX1 Crankset into the PF30 BB?
    I have three manuals and all say different things...
    And btw my frame came stock with a decent play in the front shock mount...
    Anybody else?
  100. #200
    Quote Originally Posted by TANK01 View Post
    Intenseman
    Just one screw
    Custom decals
    * Original frame decals :
    - Height : 5,7cm
    - Width : 65,5 cm
    * Custom decals : (Deformed version of the original "Specialized" logo..for the carbon protection)
    - Height : 7,2cm
    - Width : 65,5cm
    Original "Specialized" vectorized logos available here :
    S-Works Logo Vector Download Free (Brand Logos) (AI, EPS, CDR, PDF, GIF, SVG) | seeklogo.com
    Tag: Specialized - Logo Vector Download Free (Brand Logos) (AI, EPS, CDR, PDF, GIF, SVG) | seeklogo.com
    Intenseman-
    2013 S-Works Enduro Build Thread-6574.jpg2013 S-Works Enduro Build Thread-6576.jpg
    Eric
    France
