Results 1 to 8 of 8
    2013 Roval Control Carbon SL
    I've noticed a lot of play in my front hub on the front wheel, but don't know how to adjust it. Any guides or tips other than taking it into the dealer?
    Dealer... mine had similar issue. There is no pre-load adjust, its a bearing issue.
    Reputation: Focus_ua's Avatar
    Dec 2004
    Quote Originally Posted by gi02sl View Post
    Simply change your bearings.. Ore one of them that has that play..
    Hi Guys, what is the feedback on this wheels? How much abuse have you put into? Looking into buying a second hand Enduro Sworks this weekend which has them and I am slightly worried about the strenght of them.
    Then again, I have never had anything Carbon in the past.
    Reputation: rcjonessnp175's Avatar
    Aug 2010
    If its a 2013 sworks enduro it comes with the traverse sl wheels which are much better than the control ones. As they are the new all mountain carbon wheels which I put on my stumpy evo. Check the specialized web site
    Dec 2004
    They are really durable! I used them on a really hard terrain at 4-stage XCM race in Poland.
    Just control tyres pressure in the limits. 25-45psi, if i remember correctly.
    Awesome, thanks guys. I always run 40 psi and tubes so guess should be ok!
    I took the wheel in. It was just at the point that I would normally adjust the slop out. I was advised that it was within normal tolerance and it is not adjustable. The bearings still feel smooth and roll well, so I'll ride it and keep an I in things.
  1. $1200 2013 Roval Control 29 Carbon wheel set
    By onepivot in forum Specialized
    Last Post: 02-28-2015, 09:14 AM
  2. Roval Control SL 29 - Differences 2012 vs 2013?
    By S-Worker in forum Specialized
    Last Post: 04-19-2013, 07:53 AM
  3. Replies: 10
    Last Post: 04-13-2013, 09:33 PM
  4. Roval Carbon Control SL
    By g-bike in forum Specialized
    Last Post: 01-29-2012, 05:52 AM
  5. Roval Control SL Carbon
    By g-bike in forum Wheels and Tires
    Last Post: 01-13-2012, 08:54 AM
