Results 1 to 8 of 8
    2013 Epic shock noise
    Have any of you noticed a slight tick or clunk when the shock goes through the very first bit of travel or the transition from compression to rebound even with the Brain all the way open? It almost feels like it sticks just a bit. I've had the bike a couple of months and I'm not sure if it was always like that and I just never noticed or it it's something new.
    That's normal, slightly more noticeable at slower speeds and when set to firm.
    It's broken. The blue knob to adjust the fade is stuck at the firm position however it feels the same as the soft position. I thought something didn't seem right the last time out. 500 miles and it's toast, grrrrrr.
    I had the same thing happen on my 13 stumpjumper FSR and my shock ended up going bad about a week later and the dealer ended up replacing it all.
    Fixed for now, the shop just cranked it with a pair of pliers and it came unstuck. Seems like a bit of a weak link in the design. I'll run it until blows.
    Orr
    Orr is offline
    Feb 2013
    my rear shock started to do some noise in the past month , something like "oink" sound when the rear wheel got some hit from the ground, yesterday after night ride in the desert my shock started to make sounds like the oil moving or foaming while it rebound , i understood from my LBS that some air got into the brain system ,
    is anyone experience this issue ?
    Oct 2012
    Quote Originally Posted by Orr View Post
    Time to send it in; just got mine back two weeks ago from having the same problem fixed. It could be that air from the air can has migrated into the shock body. Regardless, the sooner you send it in the better. What years is yours? How long since you serviced it?
    Orr
    Orr is offline
    Feb 2013
    sunday morning it's going for the local fox distributor workshop for service ,
    i bought them 3 month ago , epic comp 2013
    it's only have to survive the ride tomorrow morning
  1. 2014 Epic World Cup Expert or 2013 Epic EVO
    By boondockermatt in forum 29er Bikes
    Last Post: 10-01-2013, 07:05 PM
  2. 2013 Specialized Epic Comp Shock w brain setup
    By Moroney167 in forum Shocks and Suspension
    Last Post: 07-08-2013, 02:54 PM
  3. Replies: 0
    Last Post: 03-16-2013, 05:24 PM
  4. Creaking noise solved Epic Carbon
    By motomech in forum Specialized
    Last Post: 10-08-2012, 10:58 AM
  5. Replies: 5
    Last Post: 07-14-2012, 05:08 PM
