Last week I purchased the carbon Expert with the auto-sag feature. It seems to give me a lot of sag, more than I would have expected for bike expected to climb. I measured it at a consistent 21mm (33%). Is that what the rest of you are getting? What do you run in the front then to balance it out?
I pump it up, sit on the bike and lean against a wall then let the air out of the red valve. I also noticed you can cycle the suspension and then let more air out, over and over and over. I assume the first try is the one that's correct.
