Results 1 to 2 of 2
    May 2005
    2013 29 SJ FSR Evo Expert BB Drain Hole?
    Would a drilling a drain hole, below the PF30 BB void the warranty on any 2013 29 SJ FSR carbon frame?
    I live and ride in Germany no matter what the weather. About six oz of water had collected inside the frame at the bottom bracket area. I suspect the water migrated in the frame along the seatpost and both of the the holes made for the command post cable routing. The hole near the shock is the one I suspect is the main culprit as I was hosing the bike off, upside down to get the large amounts of mud off of it. (Am working on a way to plug that hole or will at least shove a rag in it while hosing it off for now on).
    PB,
    I have also suffered from the same problems. The BB is a sealed cartridge so at least no damage will be caused, however I don't think that by drilling will resove the issue. I can only suggest that more care is taken when hosing down the bike.
