Results 1 to 2 of 2
    I Ride Bikes
    Reputation: Mazukea's Avatar
    2012 Camber headset bearing direct replacement.
    I'm looking for a OEM direct replacement upper and lower bearing for my Camber headset. It looks to be a FSA headset.
    I'm thinking that I might need these bearings:
    FSA HEADSET BEARINGS FROM REAL WORLD CYCLING
    Anybody can confirm this? or am I even on the right track?
    Thanks for the help!
    I like to hug trees at FULL SPEED!
    INSTAGRAM -> hawaii808MTB
    FACEBOOK -> Big Island Mountain Biking
    I Ride Bikes
    Okay after doing more research and busting out my caliper, I believe the stock headset is a FSA Orbit CF-40.
    So if that is true, then I think this pdf spells out which bearings I should look for. I also measured the OD of the upper and lower bearings and can confirm that it is 42mm(upper) and 52mm(lower).
    The direct replacement bearings are listed in the pdf as 6808-2rs and 870E-rs
    http://www.fullspeedahead.com/storag...a_NO.42-CF.pdf
  1. 6.6 bearing replacement?
    By mazafakka in forum Intense
    Last Post: 07-17-2017, 08:47 AM
  2. SB-66 Bearing Replacement
    By bridgestone14 in forum Yeti
    Last Post: 11-27-2013, 12:45 AM
  3. Headset replacement bearing....
    By Miker J in forum Specialized
    Last Post: 03-20-2013, 01:38 PM
  4. Hayes So1e Direct Replacement?
    By Longhair in forum Brake Time
    Last Post: 01-24-2013, 06:36 AM
  5. Bearing Replacement
    By lax30 in forum Intense
    Last Post: 02-04-2012, 06:45 PM
