Results 1 to 3 of 3
    Reputation: Rockrover's Avatar
    2011 Swingarm Rebuild Help
    Yesterday I decided do clean and lube my Epic and as a matter of course checked my swingarm bearings. Sure enough one of the main pivot bearings and rear chain stay dropout bearings were toast. A call to my LBS netted a complete bearing kit and went to work. The removal and instillation of the bearings went well, as did the reassembly. Then I got to thinking....did I install the conical washers (the washers that separate the swingarm from the bearings) in the correct direction? During reassembly I placed the large diameter of the washer against the bearing race thus placing the small diameter of the cone against the aluminum of the swingarm.
    This morning I got to thinking that I may have this backward. Should the minimum diameter of the conical washer be placed against the inner race of the bearing? Since there would be no side load on the bearing installing it that way(?)
    Yea I should have made a mental note when I disassembled, but I somehow missed this basic step. Guess I'm just getting old!
    Thank for the help.
    Generally the inner race of the bearing should be the only thing contacting any washer/spacer so it sounds like you will need to reverse the orientation from what you have now.
    Go here and you can find a 2011 epic fsr manual that has an exploded view of all the parts: Specialized Bicycle Components
    Thank for helping me confirm my suspicions. Definitely a 'Doh!' moment.
  1. 2011 rox shock reba RL solo rebuild kit/upgrade.
    By gtiboy87 in forum 29er Components
    Last Post: 09-11-2013, 05:36 PM
  2. 2011 Lyrik RC2L Rebuild questions
    By yohyat in forum Shocks and Suspension
    Last Post: 05-07-2013, 10:28 PM
  3. Rebuild Trek Gary Fisher Marlin 2011...
    By xycarp in forum Trek
    Last Post: 03-10-2013, 07:28 PM
  4. 2011 yeti rebuild--best shifting setup?
    By Greg Bell in forum Yeti
    Last Post: 04-14-2012, 05:13 AM
  5. Want to rebuild my 2011 enduro
    Last Post: 04-04-2012, 12:08 PM
