Results 1 to 7 of 7
    2011 epic rear brake mount 29er?
    I am in the process of building up my new 29er epic comp and I am having trouble mounting my rear brake caliper (Avid). It seems I need spacers really long to bring it up enough to accommodate a 160 rotor. Anybody do this yet and how did you get the spacers and a longer bolt? Should I just check out the local hardware store?
    get a post mount adapter like this one...
    http://www.blueskycycling.com/produc..._Type_Axle.htm
    Try to be good.
    Mtc
    Mtc is offline
    Reputation: Mtc's Avatar
    Quote Originally Posted by whybotherme
    Not even close!
    I've only seen on the fly ghetto fixes, not sure what the pro solution is. Spec must sell something.
    just ride
    Reputation: 24hrsordie's Avatar
    have your local bike shop get these on order
    http://www.bti-usa.com/public/catego...1?page=1#AV021
    BTI part #: AV-7232
    fits: fork/frame, PM-140*
    mount: 74mm
    caliper: 74mm
    rotor: 160mm
    ĽAdapts Avid 74mm calipers to fit various forks/frames and rotors
    just ride
    For mounting Magura Brakes on a PM140 rear frame use a QM 6 adaptor
    http://www.support-english.magura.co...showtopic=3790
    Quote Originally Posted by Mtc
    Not even close!
    Ha! you are right. I failed to copy the right link.
    Here is the one I meant to copy...
    Try to be good.
    rider
    Reputation: Swami Scott's Avatar
    I'm pretty sure it's a 185 post mount adapter:
    http://www.treefortbikes.com/product...ter-185mm.html
    160 to 180/185 is the same as 140 to 160 and those are post mounts on the rear. Use the longer bolts that come with the adapter.
