Results 1 to 3 of 3
    2011 Camber - Rear QR convert to 142x12 possible
    I just bought some sweet 26" Stans Flow wheelset and would like to convert it from QR to 142x12 in the rear. Will the frame allow me to do this or am I limited to just running the QR?
    Apr 2013
    The frame will not allow you to run a 12mm thru axle. If you want to run an axle you could purchase 10x135mm endcaps from stans, and run a 10mm rear DT Swiss RWS axle DT Swiss - RWS Thru bolt this will allow you to get some thru axle stiffness on a QR frame.
    Sounds like a good plan, thanks for the tip.
  1. 142x12 rear considerations?
    By powderhound82 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2012, 10:00 AM
  2. Replies: 1
    Last Post: 03-08-2012, 09:38 AM
  3. 2011 Camber rear vs 2012 (29er)
    By twenty6black in forum Specialized
    Last Post: 12-02-2011, 06:57 AM
  4. Tallboy with a 142x12 rear
    By packfill in forum Santa Cruz
    Last Post: 10-25-2011, 10:54 PM
  5. Mojo HD and 142x12 Rear
    By softailteamrider in forum Ibis
    Last Post: 05-23-2011, 02:59 AM
