Results 1 to 6 of 6
    2010 SJ FSR Expert
    I replaced my 2007 SJ Elite finally with the 2010 version. I actually bought the frame, hence the different colour and used & upgraded parts from my prv bike. Also moved up from frame size S to M.
    The aim was not to have the lightest bike possible (weighs in at 11.5-11.7 kg depending on the tire choice), but to have something of both worlds...lightness and control.
    Only thing missing is a 2011 Fox Talas FIT RLC....
    Spesh Istanbul
    and some more pics...
    Looks really good, and you have swapped some nice parts over. How are you finding it over the 2007?
    Hi...to be honest, the 2007 Stumpy was (and still is) a top class "do-it-all" ride. Only fault maybe was the light front end, especially on technical steep climbs. That was also partly solved as I had upgraded to a RP23 rear shock.
    2010 impressions - the brain works! The setup is another issue, and I am still playing around, but the shock needs more psi pressure than advised. Its a pain/shame that you can't adjust on the fly though. I wouldnt have bought it if Fox wouldnt be back. The geometry fits me perfect as I am btw a S and M size frame, and the 2010 M size is kinda in between I would say...not a real size M.
    Speshıstanbul
    Pimped my rig
    New colour job and parts, Roval Trail SL wheels, same M5 frame...
    ...and last picture with its stable mate
