    2010 Roval Control SL Hub problems
    I took my 2010 S-Works Epic into the LBS and found that Speci has had machining problems with the Roval Control SL Carbon, OS 28mm end caps hubs. I have about 20 hours on my Epi and needed to send in the front wheel to have it fixed.
    Anyone else have this problem?
    Reputation: madskatingcow's Avatar
    I just installed my new set of Roval SL 2010's, which came in about two weeks ago. Can't see anything wrong, what exactly is the problem?
    My wheels didn't come with the speciali hub caps to make a bigger contact area with the fork, though. They just weren't included in the box. According to the shop, they are never included?
    Reputation: worthy_4242's Avatar
    I just looked at mine and there is definitely a bigger contact area. But i am not sure if that is because they are the new 29er wheels. good luck figuring it out.
    I don't know. They were grinding like the bearings were shot. My LBS said that Speci said they had machining problems. I will ask when the wheel comes back and let you know. The weird thing is that I only have about 15 hours of ride time on this hub.
