Results 1 to 2 of 2
    2010 Enduro Upper Shock reducer/bolt play
    Took of RP2 to replace seals and service, play has now developed in the upper shock eye. Thought it was a bushing, but it turns out the interface with the DU bushing and custom spec reducer is just fine. There is some play between the bolt and the reducer that was probably hidden by all the grease and shit i removed when cleaning. So, i have a few questions.
    1) Is the shock stationary or does it actually move. I know the pivot points move in order to engage the shock, but how much does the shock move in its place.
    2) Wrapping the bolt in teflon tape would definitly help to reduce play but will that be a problem? This is why i am wondering if the bolt is actually rotating within that reducer.
    3) Pump a bunch of extra grease in there?
    I dont want to go out and buy an entire specialied bolt kit just to get that one reducer. I am sure at some point i will....but not now. Basically, this issue results in a slight knocking when i lift up on my seat post. I am sure that it will wear faster due to the play so i want to minimize it if i can. Bolt has been torqued right to the middle of the spec range. Thanks
    May 2017
    Quote Originally Posted by PRCVT View Post
    Hey man, did you ever figure out a solution to this? Mine is doing the same thing and a 200$bolt kit is a non option...
  1. 2010 Enduro Headtube Reducer
    By WildFingas in forum Specialized
    Last Post: 05-29-2012, 11:20 AM
  2. Trance X broken upper shock mount bolt
    By 661lee in forum Giant
    Last Post: 03-15-2012, 04:14 PM
  3. Stuck upper shock bolt
    By twangcat in forum Turner
    Last Post: 03-03-2012, 05:50 PM
  4. 2010 enduro shock eye bushing play
    By brad72 in forum Specialized
    Last Post: 08-10-2011, 11:13 PM
  5. Replies: 10
    Last Post: 06-10-2011, 02:36 PM
