Results 1 to 16 of 16
    aL1
    aL1 is offline
    Reputation: aL1's Avatar
    2009 Hardrock Sport Disc BB5 to BB7
    I want to upgrade my BB5's to BB7's-
    I'd like to mount a 160mm rotor in back, and a 185mm rotor in front if possible-
    Will the 185mm fit in the front, if it does, will I need a special adapter?
    And are Jagwire Brake Cables' worth the $$?
    Thanks-
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    Yes you do need an adapater. And I'm pretty sure it already has jagwire.
    The bike is nothing more then circles turning circles, It's the human motor that makes it elegant.
    aL1
    aL1 is offline
    Quote Originally Posted by ProjectDan35
    ProjectDan35, any idea what size or type adapter?
    Cthulhu fhtagn
    Reputation: Mike Gager's Avatar
    when you buy the bb7s they should come with the adapters i believe
    Specialized HardRock 29er
    Nashbar 29er SS
    aL1
    aL1 is offline
    Quote Originally Posted by Mike Gager
    I'll give them a call tomorrow-
    Reputation: anesthesia-matt's Avatar
    brake and cable upgrade
    Just upgraded my 2005 Hardrock from BB5 to BB7. 185mm up front and 160mm in back, adapters come with the caliper and rotor. I also have Jagwire Ripcord cables for brakes and shifters...they are AWESOME!!!
    aL1
    aL1 is offline
    Just ordered a BB7/185mm/G2 for the front with some Jagwire Ripcord Cable...getting the 160mm next week or so-
    aL1
    aL1 is offline
    Quote Originally Posted by anesthesia-matt
    Did it need any extra hardware like bolts, etc...?
    No extra hardware needed, it comes with what is needed. What kind of levers are you using? I also upgraded to Avid Speed Dial 7 levers.
    aL1
    aL1 is offline
    Thanks....
    Speed Dial 7's of course-
    I upgraded my 09 Hardrock disc to BB7s. They came with all the hardware I needed to install them. i went with 185 in the front and 160 for the rear.
    aL1
    aL1 is offline
    Quote Originally Posted by tgonzo182
    That's my plan too...after I ordered the 185, I got conflicting info regarding compatibility with the stock suntour fork (on my hardrock sport disc)-
    cougarbait
    Reputation: Lambdamaster's Avatar
    Nov 2008
    there are different models of jagwire housing, some are worthless, some are top-notch.
    I would check your fork specifications to see if it is even engineered for a 185mm rotor. If it isn't, you risk voiding warranties and snapping something.
    09AS-Rsl/09Six
    Property Inspections
    Reputation: New Light's Avatar
    May 2010
    How would a larger rotor size snap something or void warranty?
    Escondido, CA
    cougarbait
    Nov 2008
    some forks chassis are weak and can't handle the torque of a large diameter rotor (i.e. RS dart)
    32mm stanchions are typically the minimum for 185+mm rotors (only rule of thumb)
    09AS-Rsl/09Six
    Hi, anyone know if the 29er suntour fork on the Hardrock is a post or IS mount? thanks
