2009 Enduro SL w/ Cane Creek dbAir
Hi all, I ended up impulse-buying a used shock (Cane Creek dbAir) for my 09 Enduro. Does anyone know what mounting hardware I need? Also, has anyone set these up and figured out what settings to use (I'm assuming the setup is the same as with a Pitch)...
Mounting kit 8mm * 22mm
Apparently cc bushing is slightly different
Regarding bushing tools I think ?
1:18
Tip: use CC hardware, better tolerances and longer lasting than Fox or RS. Also, Fox 3-piece will damage your DB Air (search forum).
Base settings straight from the Malcolm @ CC for Enduro SL.
Carefully Open all adjusters counter clockwise. Be careful with the low speed adjusters they have small clicks, when you get near the end of the adjustment range and you feel resistance stop.
Turn Adjusters clockwise
HSR- 2.25-2.75 turns in from all out
LSR – 13-17 clicks from all out
HSC – 0.5-1.0-turns in from all out
LSC – 08-12 clicks in from all out
By gretch in forum Intense
Last Post: 02-05-2013, 08:42 PM
By modifier in forum Downhill - Freeride
Last Post: 06-04-2012, 11:51 AM
By WarBoom in forum Shocks and Suspension
Last Post: 04-27-2012, 07:55 PM
By recitio in forum Downhill - Freeride
Last Post: 02-08-2012, 03:23 PM
By Hangtime in forum Pivot Cycles
Last Post: 09-18-2011, 12:18 PM
- You may not post replies
- You may not edit your posts
Forum Rules
