Results 1 to 3 of 3
    Reputation: BubbleGum's Avatar
    Dec 2011
    2005 Enduro/SX/SX Trail parts compatibility
    Hi! I have a 2005 SX fourcross. I wonder if I can use chainstays from SX Trail and Enduro for it. I also want to know if other parts are compatible - like shock shuttles and seatstays.
    Reputation: Corvette's Avatar
    Stays are NOT compatible between SX and SX Trail/Enduro. But you can fit the stays from SX Trail to Enduro and vice versa (on 2005-2007).
    Most likely the seatstays are different as well.
    BUT - if you change the seatstay and the chainstay together, it *might* work. The SX has shorter stays, so putting longer should not interfere, but can cause other issues (handling, different shock rate, etc.)
    Dec 2011
    Too bad they are not compatible. Stays for SX Trail are much easier to find.
    Thanks for your answer!
  1. 2005 enduro chainstay
    By zstyle in forum Specialized
    Last Post: 08-31-2017, 03:58 PM
  2. DT Swiss EX200 - Enduro 2005
    By Zoomy in forum Specialized
    Last Post: 10-24-2012, 12:43 PM
  3. 2005 fsrxc parts availability?
    By Krellmachine in forum Specialized
    Last Post: 10-04-2012, 12:26 PM
  4. 2005 Manitou Dorado (Problems, Parts, Service ?)
    By heavyp in forum Shocks and Suspension
    Last Post: 09-25-2012, 01:24 AM
  5. Compatibility between frames and parts?
    By peace_keeper1517 in forum General Discussion
    Last Post: 08-29-2012, 02:10 AM
