Results 1 to 3 of 3
    Reputation: bigkeith's Avatar
    Sep 2004
    2004 stumpjumper problem
    I have an issue that I thought I should ask about be for I act.
    My stumpy is making noise when I move it about and a found the noise is coming from the rear shock and the link that attaches the rear triangle. I didn’t notice it till after a ride on Saturday. A better way to describe it is there is slack in the connection between the rear shock and the rear triangle (only on rear shock mount).
    Is this a repair issue or warranty?
    DU Bushing
    It is a repair not warranty, normal wear and tear. It's time to replace your DU Bushing. You can order the parts you need direct from FOX, it's a quick and easy fix if you've got access to a vice. Use the search function for more info.
    Sep 2004
    thanx
    off to the bike shop
  1. Angry Candian with a mullet.....
    By TheSherpa in forum Downhill - Freeride
    Last Post: 05-03-2005, 05:27 AM
  2. Replies: 67
    Last Post: 03-01-2005, 07:03 AM
